First (test) 4x8 layout in HO - updated 27 January 2009
I’m just beginning in the hobby, and after reading for a while on this forum and other resources, I thought I’d throw up what I’ve dug myself into and see what other more experienced hobbiests think.
I’d appreciate any feedback folks might have before I get too deep, especially if you see a major “duh” that I haven’t picked up yet on.
I have a site for it located here
My idea has been to work up a small layout that I can break a few times before I begin construction on “the big one”; sadly I’ve already gone through that process a bit so far. I’ve learned a fair bit, from track laying to soldering, and now I’ve recently discovered that not all magnetic couplers from different manufacturers are created equal.
Thanks you in advance for your help!
Scarpia
I’m not more experienced, I am only 15 but i am on my first layout right now to, but I have to say, it looks great, I love the scenery. Great work, keep it up, keep us posted, Mike
[wow][:O] Looks like you really did your homework! Excellent work for a first effort!!(or second, or third, etc…) Can’t wait to see it finished.
Stick with the Kadee brand couplers. They’re the best.
Thanks for your kind comments. And yeah, I just started re-installing couplers on all my models with new KDs.
[tup]
I think your doing the right thing! I have been building a 3x5 N “test” layout before I build my next one and the experience is proving invaluable. I have refined my benchwork and track laying. I have not yet started scenery… next week if I can finally finish the backdrop… but if it follows like the rest it will be a great learning experience!
I look forward to seeing more pics as you move along!
Chris
Yep. You are doing the right thing by building a test layout.
I wouldn’t buy any more kits until you see how you will be with building them. The engine house is nice, but I would consider it an “advanced” kit. The Resin car kits are also “advanced”. So get those built and then you will be able to asses your skills for advanced projects. If they are a little too hard for you now, you can always get plastic ones until your skills improve. If you take extra care with them, paint and weathering, they will look almost as good.
On your test layout, build hills with rock outcroppings and cliff faces, retaining walls, trees and bushes, bare ground, roads, water, and a bridge or two. These seem to be the most common things that every model RR has, and by building them, you will gain the experience that you seek.
I think K-dee couplers are the way to go also. You can also experiment with uncoupling magnets. I use under-the-track ones (308 I think). I cut them in half, both to save money, and because with today’s smooth running locos and refined control systems they don’t have to be as big as they come in the package. If done right, they do work as advertised, but you do have to get the alignment correct. I know a lot of modelers prefer to do their uncoupling by hand, but I do use the magnets in the hard to reach areas, and they do work good.
That’s great advice, thanks. I think you bring up some excellent ideas on how to broaden my skills.
I did misspoeak to some degree; I’m new to this hobby, but not the modeling one. I have a fair amout of experience with both resin models and scratchbuilding in other genres, so I know enough to not rush those builds. I have to say though, the engine house kit seems very well designed. I’m looking forward to getting started. The F & C cars I’ve held off so far, as I’m not sure on the process of actually mounting the trucks to the frame. I haven’t had the time to do any research on that yet.
Interesting ides on the undert track magnets. I already have some in place, but I’l make note of that in the future.
Thanks again!
This looks great. I love the documentation, and you will too later on, to refer back to, and to enjoy reliving the journey.
I too am building a test (refresher for me) layout, with the new and relearned skills to be applied to the next, bigger and better, more outlanding, making my wife wonder if I am nutty, project.
Please continue to document and share. This is exciting.
Rick
Scarpia,
Nice work on your test layout. I’ve done almost the same thing with my practice 4x8 layout. I’ve accumulated about 40 structure kits with 22 of them already built and weathered. I’ve also been buying DCC/sound equipped locomotives and rolling stock kits. Almost everything I buy fits within the context of my plan, although sometimes an impulse buy sneaks in there.
Since it’s taken me a lot longer to finish off my basement than originally planned, the practice layout gives me a place to put my stuff and try it out - although it really looks silly sitting there all crammed together.
There’s finally light at the end of the tunnel regarding my basement project so real layout construction will take place in pretty short order, but my little 4x8 has been invaluable to me during this learning period. Good luck.
Looks great. I have one suggestion for your test layout. Although probably too late, I would move your siding at the bottom and make the track coming out of the turnout longer, allowing more space between the main and the siding. This way, you can put your depot there. I saw something similar on a layout once and it looked really cool. Just my 2 cents
By the way, I love the overall track plan, and it makes me want to tear down the shelf layout and build a 4x8.
@ jblackwelljr
Sounds like we’re in the same boat! It’s hard not to buy things as you see them, so the test layout is helping scratch that itch some what. I hope you post up your main layout.
Cheers!
The only suggestion I would make would be to get some Micro Engineering bridge track to use on your bridge.
It has longer, square ties that are spaced more closely together, and also comes with the smaller code rail for the inside guardrails.
Otherwise, looks like you’re really enjoying yourself!
Lee
Funny you mention that, wm3798. I actually do have some, just wanted to get the bridge painted up before I tackled that. As the bridge is almost done (from a painting standpoint, I’m going to put some track down this week
One quick question - how do you affix the track to the bridge? just CA?
And I’m having a blast. I’ll be kind of bummed when this one is done.
Thanks in advance.
CA works fine. You’ll want to provide some weight or clamps to secure the track while it cures though.
Lee
I’ve been progressing on my test layout (updates at www.garbo.org/MRR) but I’m a bit stumped with the ME Bridge Track.
How do you affix the guard rails on the inside? The package included barrels and their stands, and some other long looking plastic tie pieces. Do these run parallel to the rails, and do the guard rails sit on top?
Thanks for any help you might be able to offer.
I use CA to secure the guard rails, and the long pieces run along the outside ends of the ties. Refer to my photo posted previously. The best way to do it is to hold the rail in place with one hand, and apply a drop or two of glue every couple of inches to the base of the rail. Capillary action will pull the glue between the rail and the ties to form a bond…but be careful not to glue your finger to the rail! (this will impede rail traffic!) Once those drops bond, go back and add a drop of glue at each tie to really secure it.
The guard rail should be bent inward at the ends, and filed down to a taper to prevent interfering with coupler pins and the like.
Note that the guard rails extend beyond the bridge structure.
Lee
Ok, thanks. So the long pieces hold the outside of the ties together, and the guard rails just sit on top of the ties themselves. I was thinking i was missing something, as the ME track is so detailed that I presumed there was another set of cleats on the inside of the ties to slide the track into.
I won’t be able to extend the guard rails too far past my bridge due to a turn out location, but I’ll see if I can get it to look right.
Thanks again!
[tup]
On the N scale version of the bridge track there is a row of tie plates that help hold the guardrails into position. Is that not present on yours?
Lee
I have to say that if that’s your first crack at building a layout, you’ve done a fantastic job.
[tup][tup]
@ WM3798 - I didn’t see them, but I’ll look closer, when I get home. Thanks.
@Rolleiman - Thanks for your kind comments!
