If you use flex track to make an unplanned curve, you may not know what the actual radius of the curve is. Here’s a link that let’s you find the radius without using the center of the circle. I used this to cut in a curved turnout.
HO Example: Chord AB (“circle 2”) = 13.5, Segment Ht ED = 1.0
(don’t enter quote " for inches)
Radius = 23"
Pretty neat link there Terry. Thanx. I took geometry in high school, I don’t remember that though. Of course that was some time ago and dirt had just been discovered a few years before that. Now to figure easements and super elevation???. Ken
super elevation doesnt really need to be calculated since its a “look cool” feature, which means it really doesnt do anything for a model it just looks cool and follows the prototype.
Yep, jadormdrache your right. I just cut small shims from old cardboard rolling stock boxes and shim the outside of the curve with that. Once the track is ballasred and scenery in it works great. If your curves look like Lowe’s motor speedy ya went too high!!! Ken
