The other day I was in my favorite train store where I showed my track plan to the guy at the counter. He responded with the idea to do the entire layout in flextrack. His resoning was less joints would cut down on derailment chances and loss of power.
Any comments on this idea?
Are there modeling tips for making the curves so they are consistant and don’t become a problem?
It’s a bit more involved than using sectional track, but it’s not really that difficult. Just make sure you draw out on your layout on your table where you want the track to go and then you can use track spikes to make sure the track holds the shape you want. I’ve done my first layout with flex track and haven’t had to many problems. It also gives you more freedom. I think it would be a good idea to look into soldering. Just my thoughts on the topic.
My process is to draw the center line of the track, lay the split roadbed to this center line, center the track on the roadbed and sight along the track to make sure it has a smooth curve and no kinks. For curves, I solder the sections together before curving into final position - this gives me a smooth curve. For electric connectivity I solder (resin core) most other sections together, but leave some for expansion. One advantage of flex track is that I can use easements, I made a template for them.
With curves the rails become uneven, I trim them with a cut off disk in a dremel motor tool - other use rail nippers. I use a small file after the cut to clean up any burrs and square the end. I also use a wirebrush in the dremel on the rail before soldering it.
There are other ways/variations of doing it, but this works for me. Don’t be afraid to to rip up a section and redo it. I don’t do this often, but when the results aren’t right I redo it.
So there is more process in flex track vs sectional, but I think the ability to lay any curve radius and easements is worth it.
I’ve always used only flex track to build my layouts for the simple reason that I can make the curves any radius I want and the fact that there is less joints is a big plus for keeping good electrical circuit and not having to contend with loose rail joiners.
It’s like welded rail on the prototype. And I usually solder all of my rail joints, especially on curves.
The only exception to this is when I built a layout using Kato Unitrack. This stuff is great but you don’t have the options to use whatever radius curve you need.
Soldering of joints on flextrack with feeders pretty much makes a solid track.
Get a yard stick. Drill a hole large enough for a pencil at a mark… 22" for example. Pin down one end of the yard stick and stick a pencil in the 22" mark. Swing that pencil around your plywood in a curved line. (You might also use a camera tripod for center marks “Off benchwork”)
Your cork roadbed will be in half. One half this side of your pencil mark and the other half to finish the curve subroadbed. Flext track goes onto top of that with spikes. Actually very small nails, but I call them spikes. Most people glue them today.
Careful steady progress checking as you go for quality is the best path to track work.
Me? Im lazy and tired, I just flop down Kato Unitrack and go.
Anytime you can use flextrak instead of sectional track, do it. Sectional track is electrical and operating problems waiting to happen. Every joint is an electrical and mechincal weak spot. Flex track minimizes the risk by eliminating joints.
Flex track also gives you 100 times more flexibility in track design. You are no longer limited to fixed radii and fixed curve lengths.
A couple of helpful hints, and some tools you’ll need:
Tools:
Trammel - a yardstick with holes in it, one for the pencil you,ll use for curves and one for each radius curve you wish to use.
Rail cutters - I use diagonal-cutting pliers, others use specialty rail nippers, cutoff discs in motor tools or even fine-toothed hobby saws.
Flat file - pick a decent-size one with fine teeth.
Hints:
If you use flex track with one fixed rail (Atlas code 100, for one,) lay curves with the fixed rail to the outside. That way, you won’t be removing ties when you trim the inner rail.
Use that file to clean up EVERY rail end. Flex track fresh out of the box has burrs on the rail ends, usually on the bottom but sometimes on the railhead as well. Bottom burrs interfere with rail joiners, and wheel flanges will detect every imperfection they encounter. I strongly recommend taking the sharp corner off every railhead, leaving a tapered area about .05 inches long and .01 inch deep at the rail end.
Don’t depend on rail joiners to conduct electricity unless they are solidly soldered to both rail ends. I solder jumpers around them (as does the prototype, for signal detection.) Other modelers prefer to solder a drop (rail power connection) to every section of rail.
Leave a little breathing room at rail joiners. Don’t butt the rails solidly against one another or you will run into problems when the temperature and humidity change. Even Tony Koester had to re-learn that solidly-butted rails lead to rail heaving.
As soon as you have a couple of sections laid, choose your most derailment-prone rolling stock and push it back and forth on the new track. If there are any problems. fix them immediately. That way, when you lay the last of your track, those last few lengths will be the only ones you’ll have to run check.
I bought a complete layout from Atlas using sectional track and decided to make a few changes where I had to use flextrak. After I learned how to use flex track I decided that flextrak was the only way to go. Not only does it give you a little more freedom but it looks better with out all the joints. The only think I will do differently on my next layout besides using flex track, is that I would buy a track cutting tool to keep the rails from twisting and spaced.
One advantage to the sectional track is that I wanted to add a turnout for a lumber mill after I had the all the track laid and it made it real easy to cut out a section piece.
I don’t think I’ve ever used anything but flex on my layouts. The biggest thing with curves is to solder your rail joiners as you lay the curve so you don’t get kinks in the rails. It’s not hard to do though. You just lay most of the curve, then trim the rails, romove a tie or two (save them for reuse later), solder on the next piece, then continue on your way around the curve. One everything is set, take the ties and shave the spikes off and slip them into place with some glue or caulk (my favorite).
Now that you’ve made the jump from sectional to flex take a new look at your plan. Probably you have made some compromises to get the track to work with sectional. You now have the opportunity to go back and re-think those compromises.
I agree with Paul here. I finally ripped out a couple of small sections that either didn’t look right (not smooth curves) or didn’t work well (poor prep of the roadbed on which the track must rest to be stable). I did so out of desperation the first time, and thought I had gone backwards. Turns out it was entirely the thing to do because I got it right the second time with the expected results. For the second section, I just ripped it up and had new track ballasted in a couple of hours.
So, yes, flextrack takes lots more care, but that is part of the whole model train experience and learning. It comes quickly, you smile more, and when you are finally running trains, you will never look back.
Do pay attention to your rail ends. Wherever there are two rails that meet, use a metal file to bevel the tire surface on the rail head, as well as bevel the flange faces. This is important for smooth running, particularly on tighter curves where flanges tend to get pressed toward the outer rail on a curve. As they encounter joins, they will glide over what amount to tiny cam surfaces if you remember to take the time to construct your joins well. [I learned this from Chuck, above, and endorse his tip whole-heartedly. [:D]]
Flex lets you do easements which makes it worth it all by itself. I get nice smooth curves and am free to design my track plans anyway I please. Its a little more challenging to work with but, for me, the results are worth the effort. You will want rail nippers, a soldering iron, and a little more planning to do it right. The down side is you can’t test fit your track plan.
I would suggest trying to find a tutorial online or in print and then decide if it looks like something you would like to do. There is a youtube video out there, search for “Weathering and Installing Code 55 Flex Track: Part 1”. I haven’t watched it but the guy did a great job with his scenery videos so perhaps it will help.
