Flux
I am wiring all track segments and switches to my bus lines. I have been using liquid flux, but I am now out of flux and need to order more. I have never used paste flux before. I am interested in your opinion of which flux you like best, liquid or paste. I have a lot of soldering to do! Thanks,
Jack
I’ve been soldering for 70 years and never used liquid always paste. Toothpick as an applicator works great for the rails.
Mel
My Model Railroad
Bakersfield, California
I used liquid at one time until I knocked it over and fried 2 circuit breakers. Paste for me!
Jack,
I’ve used both. The paste is nice because its more “controllable” than liquid. As Mel suggested, a tiny dab on the end of the toothpick is generally all you’ll need to assure a good shiny solder joint. I would still clean off the solder joint after soldering with either Flux-Off or 91% alcohol and a Q-tip.
Having said that, if you expose liquid flux to the air long enough it will partially solified into a “paste” or goo. I used to use that trick all the time when I was an electronics tech.
I’ve been using liquid for about forever.
I use a toothpick to apply it, the same as the paste users.
Ed
Paste. I first saw someone soldering while watching Tim Warris explaining how to make his style of turnouts. He used paste, and so have I to date. It stays put. I also use a toothpick, and use a larger one to uncouple cars. Ain’t pointy wood thingies grand?
No reason to get so technical, Crandell…[8-|]
The flux I use has a third option - gel. I thought it might be useful, but I haven’t used any in some 9 or 10 years of buying it. I always use the jar of paste. They actually recommend not buying the liquid unless you positively have a reason to use it - you can just add some de-ionized water to the gel or paste and make liquid if you need it. This flux is water soluable.
i never found a need to use flux for electrical soldering. I use resin core solder. When I touch the solder to the heated metal, the flux melts first and then the solder. Of course the metal can’t be dirty. I solder feeders to track and NS track to track.
i use paste when i solder copper pipe which i clean with sandpaper until shinny.
The “Rosin” in “Rosin Core Solder” is the flux [;)]
I prefer paste myself, both solder and flux.
I rarely use liquid flux, unless Im simply tinning wires for through-hole PCBs. Dip them in, touch the iron to them and hit with a bit of silver solder.
I generally don’t use extra flux for any electronic assembly. For surface mount components on a board it’s essential. But for soldering rail, when unless you hit it with the ‘wire’ wheel (the nylon or whetever one - a regular steel wire wheel will damage the soft nickel silver, or clear the nickel plating right off wheels) in the dremel right before soldering, just won’t be all that clean, I use the paste.
I use a no clean flux pen. works great!
got it from digikey
Manufacturer
Chip Quik Inc.
Manufacturer Part Number
CQ4LF
Description
FLUX - NO CLEAN PEN 0.34 OZ
I’m definitely no authority in advice soldering rail joints or feeders.
I left off 35 years ago and always melted the railroad ties.
I am very good at sweating copper plumbing pipe though. I know the most important thing about getting a proper flow of solder and a quality solder joint is in the preparation, how clean you get the surfaces to be soldered before you start.
I think flux is kind of secondary to that. I think any quality flux should do the trick.
Then again I’m no rail soldering authority figure.
I do believe what I said above is true and very important though.
Tom why do you clean off the joint? I haven’t cleaned any [:|]. If they sew more than a year old should I still clean them?
Cleaning the joint is habit for me - both before and after soldering. I like to remove any residue and remnants of the process.
A few years back somebody connected with the wiring procedures in the Redstone missile program wrote to MR about how to do better soldering. He said you should almost never have to use extra flux, and should make sure the metal is clean instead.
This last stint of layout wiring, I used a triangular needle file to scrape the rail sides until they were shiny, and also lightly scraped the wire. It works great, makes a fast joint, is secure, and not nearly as messy as using extra flux.
