Ripped off the yellow swatter (save the metal “catgut” bars: good size for pipes / rods) & soldered two wires to the contacts: a short “hot” (red) and a long black with an alligator clip on the other end:
!(http://i1192.photobucket.com/albums/aa332/mcfujiwara/toolz n gadgets/DSC05464.jpg)
The electrical tape is over the solder to prevent shorts.
Found a good-sized mesh strainer at Target for $2 & cut off the ends:
!(http://i1192.photobucket.com/albums/aa332/mcfujiwara/toolz n gadgets/DSC05465.jpg)
Wrapped the handles in electrical tape and then inserted them into the handle:
!(http://i1192.photobucket.com/albums/aa332/mcfujiwara/toolz n gadgets/DSC05467.jpg)
I found two small stacked chuncks of 1/8" masonite fit perfectly between the gaps, holding the strainer in place.
Solder the short hot (red) wire to the mesh of the strainer.
Ta-da:
!(http://i1192.photobucket.com/albums/aa332/mcfujiwara/toolz n gadgets/DSC05466.jpg)
I use a T-pin to ground the black wire into the foam.
I spray alcohol / water onto the area I want to work on, paint some thick white glue, place the static grass in the strainer, press the button and then shake softly back and forth over the area. Vacuum right away (with the nozzle a safe distance away) to get the loose grass / excess off before everything dries.
There’s a first application of WS dark green static grass here on the front right:
!(http://i1192.photobucket.com/albums/aa332/mcfujiwara/Mt Coffin and Kalama RR/P8080137.jpg)
[This is N-scale.] Need to get some 6mm grass and some other colors for some variation.
Warning: as this unit isn’t as powerful as the Noch, the strainer nee
