Went by Diamond Hill Plywood in Raleigh. Lady was real nice. Sent me out to warehouse. I took [Jim Apitz suggested] a 1/2 inch drywall screw to see if it would hold screws. Checked Homasote. OK. Checked the Celetex Soundboard. Put screw in about half way [around 1/4 inch]. Lifted one corner of 4X8 sheet 2 feet off of stack. Sold me. Maybe a little more pourous but can be sealed with a coat of paint [Geno’s suggestion]. Also, glueing down grass, ballast and etc will also seal. $8+ per sheet versus $20+ per sheet. Do the math. Only problem [which is not one really]. Can not buy direct from Diamond Hill. Even Son-in-law can not and he is a registered building contractor. Got to get it through Lowe’s. Lady at Lowe’s told me she would sell it at her cost if I picked it up. Not a bad deal. I do have a Home Depot gift card I was going to use. Home Depot can’t even find both products. No wonder they are gong broke.
You certainly have my attention! I remember Celotex as a kid, when I helped my Dad build a couple of houses in Ill., Most people out here have no idea what it is, Home Depot never heard of it. But can get it at Lowes, Homosite is only available at a couple of specialtiy lumber yards. I think I will follow your trail on this one.
Both. You can find a product that will do the same job at a cheaper price. [Comes from my years in fleet management for the State. You have a job to be done, draw up a spec for a vehicle that will handle it and bid it out. If Ford, Chevy and Chrysler have vehicles that meet the spec, why by Chevy becasue I love them if Ford or Chrysler is cheaper and does the job?]
Right the Celotex I am familiar with was black, and had Celotex printed all over the side. Came in a 4x8 sheet. Was used on the outside of the house framing. Usually made a mell of a hess on a saw blade. I thought it had a oil or tar base material in the coating. Used roofing nails to secure it.
Chief, thanks for the report! Our Lowes has 4x8 Celotex sheets available for under $10. Only one place in town had Homasote and it was $30 for a 4x8 sheet! [:O]
I’ve used ceiling tiles, like Frank53, with good success in the past, but I will probably give the Celotex a try next time.
Chief, Your right! I went to their website and sure enough the Soundstop is definetely different than what I was accomosted to. They even do a comparison with Homosite. Thanks for the clarification.
Couldn’t find Homasote board, went to local Home Depot, when I was putting together my layout so I just went with half inch plywood covered with Life Like grass mat, I know that I have a sound problem but who is going to complain other than my wife as my neighbors are about an acre & a half away from my house? Didn’t know about Celetex Soundboard either. See what you can learn by beeing a builder! Other comment about Home Depot is they stopped carrying certain light bulbs, had to go to Ace Hardware.
What I do when moving stuff around is to use a small flat-tip screwdriver to remove stuff then a little Squadron Green putty over the hole and some loose mat material to fill in over top of the putty.
Well, that’s because Home Depot is focusing on selling more important things like blenders and toasters and laundry detergent and refrigerator packs of soda. After all, who needs hardware and building supplies?
I believe your thinking of “Asphalt impregnated board”. Used regularly in the 70’s and early 80’s. As Chief stated, 4x8 wafer board became so economical, framers just covered the whole house with wafer, and cut out the doors and windows.
Spank,
As a manager of a independant lumber yard and DO-IT-BEST hardware store, the Home Depot down the street is our friend. They frustrate the customer, we help them.
Chief,
Your right on the money. The sound board does the job for a third the cost. Thanks for clarifying the issue. All I’ve used is sound board, does all I need.
All,
Stop by your local independent lumber yard. They should be able to help you. Sorry for the plug, but I was raised to be independent. [:)]
In reply to what c50truck mentioned about wafer board being so economical that even roofers used it a few miles north of Homestead FL, Naranja Lakes condo’s, before hurricane Andrew hit. I talked to a roofer about Homestead and he said that he would never re-roof in Naranja Lakes as it would be too expensive to remove the wafer board and do it legally.
This is just to let you know what extent people have used wafer board for.
I don’t know a thing about building legally in huricane country. Here in the Inland Northwest of Washington, our worst fears are loosing a single or two, or having a pine tree topple. I never blame a product or toy train for it’s misuse. Thus we are here comparing notes on sound board ver. Homasote.
Side note. Yes, it always cost more to do the job right the second time, than the first.
Every time the subject of benchwork and subtop covering comes up, all of the opinions about this and that building material comes up- fine, we all have our opinions and stories about just about every type of sheet product out there. I just wish for once those individuals who make strong negative comments about any building material (or construction technique) back it up with some real facts.
What is now known as wafer board, OSB (oriented strand board), is now an accepted exterior sheathing product. It once had a notorious reputation, but educating builders in the proper use of it has made it a very common item used in both commercial and residential building sites. OSB also enjoys a similar price point advantage over exterior-grade plywood- in most cases with two similarly-performing products, the lower priced out is used more often by far.
Chief- glad the sound board worked out for you. In construction any material of this type is typically installed with drywall, or covered with subtop or flooring- so the whole issue of screw retention is a moot point to me.
Geno, screw retention is important in the Chief’s application because he wants to secure the track to just the Celotex. If he were to use a longer screw that drove into the wood table top, it would transfer much more noise, defeating the purpose of the sound deadening layer.
And not for nothing, but if I were having a home built, I’d make sure ext. grade plywood was used. Especially on the roof. Just my preferrence, and I’d be happy to pay the extra price.
jaabat,
I caught Chief’s screw requirement at the beginning of the thread. And I’m aware about the whole noise transfer deal with screws run down through to the framing (why my roadbed and track are glued and pinned down).
I’ve sheathed roofs with both OSB and plywood- in some cases (like with concrete and clay tile roofs) plywood is the only choice. Other times, OSB is used to save money or cut corners[sigh]- hey, I just swing the hammer. Most high-end and custom residential jobs do go with plwood for exterior sheathing. But alot of spec homes get the OSB- even on the roof. I prefer plwood too, but for interior shear walls OSB works just fine.
Rod, sadly we don’t have that option in our area: Home Depot came in and ran the 2 local hardware chains out of business, Rickels and Channel, and did the same with the 3-4 lumber yards that were in our area. Of course, Rickels and Channel deserved it, as they had “diversified” into housewares and pressboard furniture. They lost focus on their core competency just as Home Depot is doing now. It’s frustrating that in the 10+ years since Home Depot came in, their harware section has shrunk from 1.5 aisles to around half an aisle. Forget about trying to find odd sizes: they don’t carry anything but the most popular sizes now.
