Another request from an aged novice with my first layout build.
I have installed an area of yard and industry track on my modest layout with Walthers Code 83 track and turnouts. The turnouts are powered using the Rapido Railcrew switch machines.
I want to power all the frogs which the switch machines allow for, but I was puzzled when I tried to check the frog polarity and continuity on the working circuit, the power being supplied by an NCE SB5 Power Booster. I could not get any polarity or continuity readings on the frogs no matter what power reversals I made nor the checks I made to all of the wiring and connections.
Finally, I decided to set up a test turnout on a box that I knocked together complete with working switch machine and frog wiring. This time I used a plain 12 DC transformer so that I could check the results without a DCC circuit. Everything worked perfectly!
My question: how can I test for frog polarity on the working DCC circuit?
At the moment I can disconnect the SB5 booster and temporarily use the simple DC 12v transformer to test all the switch frogs as a work-around. But I would like to know how many of you do test frogs on a working DCC circuit. Obviously, something here that is beyond my understanding.
Thanks very much for that information MrMe.
I can understand the DCC circuit output configuration but I certainly didnât think of your solution which to me, at least, is very clever.
I will try this tomorrow.
In addition to the other good replies, I do the following:
Ensure Rail A and Rail B have the same wiring pattern. I use RED wire for Rail A and BLACK wire for Rail B. I do this everywhere and that prevents polarily and phase errors. This is very important.
My own pratice: Put insulated rail joiners on each track out of the frog. Put feeders past the insulated joiners. This ensures proper polarity and phase and addtionally does not depend on points to carry track current. Optional, but this has worked for me for many years.
Well, I guess my ages old knowledge of electronics is long past its 'best before date"!
I have tried testing three turnouts that are wired for frog polarity and continuity and I canât make sense of the readings that Iâm getting.
What is the best setting on a digital multimeter to use in order to take meaningful readings of the frog/rail configurations? What kind of readings should I expect to see?
Is it still advisable to disconnect one of the bus/rail leads from the SB5 booster for testing the frogs? I have tried without one rail feed and with both rails powered. It didnât help my confusion.
NOTE: the paragraphs that follow are misleading or in error. I leave them here (quoted) to keep sense in several later posts.
See the later NMRA reference gregc provides for the actual modulation: it is a square wave pulse train that is âmirroredâ to the opposite polarity pulse by pulse. The effect is a waveform that would look a bit like frequency-modulated radio if you used an oscilloscope â the important detail being that the voltage âactsâ like high-frequency AC to a meter, but not fixed-frequency AC.
For reference: NMRA S9.1
Youâve already found the best âtroubleshootingâ for continuity⌠which is to apply straight DC to the track and eliminate any shorts.
I have decided to do just what you have confirmed for me; apply a simple DC power source to the circuits to make it easier for me to test for correct frog configurations.
AC volts (~), not DC (-) and typically 20V. Just measure the voltage across the rails to see a typical reading and what you should measure between the frog and one of the rails
DCC should measure ~14V AC. youâll often read ~ 1V when the polarity is the same (i.e. no volts, zero volts) meaning both probes are at the same polarity
when was this ever advisable? how can you measure voltage if one booster connections is disconnected?
I faced this same dilemma when i tried to figure out the proper wiring to juice a dbl crossover. I ended up just completely disconnecting the tracks from my power supply and removed all the locos from the tracks and just did a continuity test using the lowest ohms setting on my multi meter.
@user1234 After i got the frog juicer working i still occasionally have problems with some engines stalling briefly then proceeding did your setup with the isolated portion of rail joined up with the points help with that?
I put feeders near the points, and feeders directly after the insulated joiners on both frog tracks. No issue with engine stalling over the turnout. Peco turnouts switch the current at the points to the correct frog track and that helps a lot - no stalling.
FWIW - I had one Locomotive CP F7 A Unit - that stalled. I nailed it down to a defective truck. I sent it back for repair and got it back fully fixed. No stalling after that. This was a locomitive issue; not a track issue.
Get a bulb rated for 12-15V, connect wires to it, and then touch one wire to the frog and the other to each rail. When when the bulb lights up the frog and rail are opposite phases so the frog is connected to the other rail.When the bulb is dark the frog and rail are the same phase so the frog is connect to that rail. If the bulb is dark touching either rail, then the frog is open, not connected to either rail. Others have suggested a 14-volt to 16-volt incandescent bulb such as #1445 or #1815 with soldered alligator clips.
I have a 12v test lamp with an incandescent bulb but it doesnât work on the DCC SB5 booster circuit. It requires a standard 12v DC supply which I can apply by disconnecting the SB5 and using a simple 12v DC input instead.
Thanks for the answers to my questions.
Now I feel encouraged to use the multimeter to determine the correct arrangement of the frog control by applying your information.
Iâm going to take some readings and then report them to you if I require more clarification on the results.
He means, of course, that the two test points are synchronized in their âtransitions between two equal voltage levels that have opposite polarityâ. If they are not, the resultant will be close to, if not wholly, zero (as the pulsetrains cancel each other out).
