Diesel engines this goes for all diesel engines will not and do not use the same oil as what you would put in a gasoline car. The oil in diesels is thicker and heavier than what you would put in a car. The thicker oil will seal the rings better and protect the bearings more efficently.
The diesel fuel used in a locomotive prime mover is just about the same as what you would find at the service pumps at your local gas station. There are different grades used for specific conditions. The one that is used the most is grade # 2 diesel, which has a medium viscosity (thickness), this provides proper opperating traits for the widest range of conditions. Sometimes railroads will use grade #1 diesel which is thiner than grade #2 and therefore is recommened as a winter fuel to prevent the paraffin (wax) in diesel fuel from separating and causing it to cloud up, thus cloging the fuel filters and preventing engine operatation.
I’m sorry about the last one I’m not all that up on grease technology too much. All I can tell you here is that grease is mainly based off of the thickener it has. Many of those thickeners are alkali metals of Calcium, Lithium, Sodium, and Aluminum.
You say the oil is heavier than that for cars? Does that include diesel cars too? ( lots of european cars have diesel engines, even the smallest city cars)
Now, what can you tell me about engine maintenance procedures with diesel locomotives?
How often is the oil changed? How often are axles re-greased? etc.
What else needs to be done periodically on a diesel locomotive?
Here are the typical diesel prime mover maintence prceedures
Replacing the fuel filters, oil filters or cleaning, draining oil, replacing air filter elements, inspecting engine and related systems, adjusting (if needed) valve and injector timing, um… and servicing emission control systems.
I’m not too sure what the actuall maintence intervals are they vary (spelling) in terms of what type of prime mover is equiped in the locomotive.
Um… lets see here. You are correct anything that has a diesel engine is going to requirer heavier duty oil than a typical gas engine.
It almost seems as if you need to send me an e-mail lol.
There is one more thing. In a pentrex video I’ve seen something like this: a guy going around from wheel to wheel on an electric locomotive and puting some lubricant. The pentrex narator mentioned it, but it didn’t really explained it.
What was that guy doing and is this done today too?
p.s. What did you mean about an e-mail? You think we should continue this by e-mail?
I think this might be helpfull for others when they search archives, don’t you think?
I can’t say for sure about locomotives, but we use the same engines in large tugs. Typically EMD 16-567’s or 16-645’s. The lube oil we use is Rotella T-40 or equivalent, or Mobil Guard 40, or equivelant. The Rotella and equivlent are petroleuom based oils with special additives for heavy diesel engine use. The Mobil Guard and equivalent oils are synthetic. The synthetic oils are “much” more expensive, but the engines run much cleaner and longer with them. Our oil change intervals run anywhere from 500 to 1500 hours of operation, depending on the type of oil and filteration systems that are installed.
The diesel fuel is the basically the same as you get at the filling station. It has been dyed to signify that no road taxes have been paid on it. You get caught with it in your vehicle and you can get a big fine for tax evasion.
In the axle bearings it is probaly extremly high pressure grease ont he roller bearings. The one I hauled a load of looked to have some form of axle grease. For the gears off of the traction motors standard heavy duty gear oil.
I think everyone’s right on the diesel fuel, one extra point is that high sulfur diesel fuel is also dyed so that the two aren’t mixed. Low sulfur diesel in an engine designed for high sulfur fuel usually means seized up injectors or injection pump. The color dye here is red for both, I believe.
Lube oil, I believe, is usually like a 15W-40 viscosity, I believe EMD requires synthetic lube in their engines as a condition on their warranty.
Axle bearings get gear oil, I think it’s 80W90 gear oil, at least on the serviceable ones. Sealed bearings get some sort of grease, possibly like Mobil 007 lube.
Traction motor gearcases get what’s called crater, at least that’s what it was called when I worked for the WSOR. It comes in packets, you just toss the entire packet in, plastic bag and all, and let the gears break open the bag and spread it around. It is also difficult to get out of clothing (ask me how I know!!)
Having owned a couple of diesel cars, I can tell you that the oil changes have to be done more frequently than on a gasoline engine. My first diesel car was a Rover Maestro which needed and oil change every 5000 miles; on the gasoline version the frequency was 6000 miles. Then I had a Seat Ibiza diesel; the relevant figures were 10,000 miles and 12,000 miles respectively.
