Gear Shim Material
I have seen where some have used Kadee shims for helping to align and center gears in HO locos, but the ones I have seem to be made of a paper-type material that might degrade. Are home-made styrene shims a better idea? When you use a mild lubricant such as ATF or Labelle’s, would that be enough to avoid wear and tear on the styrene, or is there an alternative material? Cedarwoodron
I wonder if you could explain (preferably with photos) gear shimming? [:^)] If you’re talking about taking end-play out of worms, NorthWest Short Line makes thrust washers in various sizes and thickness. They’re bronze and made specifically for such work. They’re also useful for removing side-play from other types of gears. If you need to shim a gearbox (increase the width of a split-sided one) or increase clearances for a bottom coverplate, brass shim stock is available in increments of .001". You can cut this material with a knife or scissors, at least in the thinner sizes.
Those Kadee washers are hard pressed fiber, and will work fine as gear shims. In fact, Lionel used to make some of their O gauge motor gears from pressed fiber back in the 20’s and 30’s, and they held up very well as long as they were made properly.
