Hello All,
I began to revisit my roster of Athearn Genesis F units to perform some maintenance (burned out headlights [:-^]) and to install sound decoders in a few that could use them…
SO— while removing the draft gear from some of the engines I found that several of the housings had cleanly split in half. No worries, says I, I’ll just order a dozen or so…
Not!
HO Coupler Box, F7 (2) $4.98
[ATHG19258]
No Longer In Stock, Discontinued Item
There’s not much room behind the pilot and ahead of the truck and I’m sure I could modify any of the available Kadee products (#252 box) but you see these Athearn ones have a pin that engages the frame and holds the box from swinging and they “just” fit with clearance to the truck so I’d really like to find something close to OEM.
Any Ideas??? [:^)]
Ed
