Clearly most wood doesnt bend. Be great if it would. Pardon the pun.
Out of a piece of wood which is perhaps 120mm wide and length is irrelevant, but say 400mm long, at which angles would we need to cut to obtain 12 pieces to make a semi-circle?
I say 15 degrees. The old man says 7.5 degrees with 24 cuts.
Neither of you is correct, but your old man knows his math a little better!
A semi circle has a curvature of 180 degrees, for 12 pieces of timber that makes 15 degrees for each piece, but 7.5 degrees on each end! This makes 24 cuts, but as you want to form a semi circle, you can omit the cuts at each end. That makes it 7.5 degrees and 22 cuts!
But if you ignore the square ends, you only get 165 degrees of turn.
I do suspect that cutting the pieces “in the flat” (13 cuts) will be faster than stacking the pieces. I am wary of dealing with the three pieces “meandering” while I cut.
That’s what the supplied clamp is for with most chop saws or sliding compound miter saws. But the time to line up and set clamp I can duplicate the other 2 to 3 pieces. You may do just as I do, the info is for ones that want to make multiple cuts.
13 pieces of wood, 2 of them with a 7.5 degree angle cut on one end and flat on the other, and the other 11 with a 7.5 degreen angle cut on both ends is 22 angles of 7.5 degrees, which is 180 degrees. With the two flat ends, perfect to attach to a rectangular bench to add a curved end.
I did say 13 CUTS of one “plank” to get 12 pieces with 7.5 degree ends.
Each piece of the 12 subtends 2 x 7.5 degrees = 15 degrees
12 pieces x 15 degrees = 180 degrees.
So this design will mate perfectly with an edge of a straight table.
I do agree you can make a 180 degree turn with 13 pieces, the way you describe. And it will probably work. But it’s not the “official” way–it is inaccurate. But probably accurate enough for model railroad benchwork.
You’ve also got to design the two “custom” ends. They’re different than the other 11–they have different dimensions.
With the “12” method, all pieces are the same. Plus it’s easy to dimension the pieces–check out J. C.'s link, above.
After all the disussion of cutting and math, I too was wondering the use of the semi-circle. figured at first it is roadbed for a turn, but why cut so short. normally cookie cutter , you can just draw the radius on plywood to cut out the arcs. These pieces and cuts are more what you would do for a helix, but with numerous pieces for the spiral.
Also true, unless you are building cabinet-grade benchwork and want it to be as round as possible for some aesthetic reason. I don’t like perfectly square ends, the 90 degree angle ends up punching people in the gut (or even more painful areas depending on their height and the height of the benchwork) so splitting it out into a few pieces is probably preferable to making it square.
Heh - have you checked out the 2x2s that Loewe’s sells? Most if them look like bacon. I bought one strictly for use as a prop in my benchwork clinic to get a laugh (I use 2x2s for legs). I say it may not be much as a benchwork leg but it makes a great template for easement curves.
