Getting an F-Unit Windshield
So I like the C&Os BL2s, they don’t work for my layout. But I got three of em. Two are painted and one is undecorated. I plan on turning the undecorated one into C&O 1844, which was rebuilt with an F-unit style windshield after a run-in with a snowplow.
What is the best way to get an F-unit windshield without killing a model that is over $60. I currently am throwing around the idea of getting a busted-up Proto E8, which I can turn into a Crandall cab.
Is there a better way to get a windshield?
Cut them from clear styrene sheet.
Mike.
Basket case F units are – well maybe not a dime a dozen, but plentiful at swap meets; problem is swap meets are not plentiful at thtis time. One little accuracy issue is that the real experts on the EMD bulldog nose seem not to agree on which manufacturer actually came closest to being accurate. And in point of fact I have seen prototype photos of E and F units lined up next to each other and there are perceptible differences in the profiles.
In looking at online photos of 1844 (and noting that there are other detail differences from a “stock” BL2 so this could end up being a very interesting project), it struck me that working with the original windshield – filing or using bits of styrene or even bondo plus filing – could end up with the look you seek. In fact the old AHM BL2’s windshield looks more F-unit-ee (to coin a word) than BL2-ee (to coin another).
Do you by chance have an old Walthers diesel dress up kit in your stash? The F unit windshild casting in clear plastic could perhaps be a guide to the changes you’d need to make to the model. I do not know if Walthers still offers the diesel dress up kit – that was the last word in super detailing 50 years ago – but there are laser cut clear acrylic F unit windshield inserts out there.
Dave Nelson
Does anyone make a model 1936 Chevrolet?[}:)] Informed rumor says their windshields are what the early EMD cabs used on each side (cuts down parts cost and replacement sourcing, among other things).
Seriously… since they are flat, they would be easy to cut from cover slips (by nibbling to the line if you have to) and the glass will give you a far better look than any plastic if you can properly file and level the inside of the windshield openings…
American Model Builders makes F unit windshields in two versions; scale and semi-scale. You can order online. Detail Associates used to make them, as well, but finding them might be difficult.
http://www.laserkit.com/windowho2.htm
I bought some of those Walthers diesel dress-up kits several years ago. I think they were on close out, and they are now listed as out-of-stock.
Each kit contained a set of all the windows for an Athearn F7 A/B set, including the round portholes. It also had all the wire grabs.
I was going to suggest AMB (Laser Kit) as well. I haven’t used their F series windows but I have used their windows on several Athearn BB caboose kits and the fit and quality are impressive! No glue required.
Dave
I cannot find a picture of this C&O locomotive to see what is different about it.
-Kevin
I believe the OP is looking for the entire windshield assembly, not just the glazing.
And the as built windshield:
Regards, Ed
Is it possible that only the starboard window on 1844 was replaced? Because the port one looks visibly larger, and more BL2-shaped, at its outer end if you enlarge the picture, and its inner corner and edge behind the angled numberboards may be too.
I cut windshields for a pair of Athearn F units out of clear plastic sheet. Not too hard to do.
Thanks Ed.
I had to examine the pictures to see the slight profile differences. I never would have noticed it on my own.
-Kevin
Much of this conversation seems to be geared toward the F-unit glazing.
I believe the OP is looking for the entire cab-area of an F unit to do the surgery needed to fit it into place where the original BL-2 cab is located. This seems to be what C&O did to repair the damage to the 1844.
Apparently the roof outline and nose outline are close enough that a few razor-saw cuts can result in a swap of the cabs.
There’s the Highliner shell, of course but these run about $60 on the open market. I have a few Alco PA and FA shells on hand but I’m not sure of an EMD. I’ll have to take a look. I might have a BLI F7 shell around.
Wreck repair can cause some unique opportunities for the modeler. In the '50s there was a pair of NYC E7s wrecked and EMD repaired them with E8 parts.
There are other examples of course.
Regards, Ed
I don’t think anything can help the looks of a BL-2 [(-D]
Seriously, there are F7 shells on Ebay, some going for $3. I’m sure I have a few shells in the parts box as well.
Mike.
well I’m looking for really accurate windshields,meaning no BB, Tyco, or Bachmann. I can’t really think of a way to get a cheap donor
Then Highliner/Genesis is your choice in HO.
Regards, Ed
I have a set of these:
https://highlinersonline.com/
Good luck.
Mike.
Vintage Walthers U822 HO Athearn F7/9 Diesel Loco Dress-Up Kit BLACK GRABS 822 | eBay
I just bought one on ebay.
He has one left.
American Model Builders has a kit that corrects the Athearn blue box windshields. Maybe that would work.
The roof profile of any donor may differ from the LL BL2 but there is probably enough shell thickness to file to a match.
