Hello All,
I have my preferences for roadbed but I refrain from telling people what not to use.
The Woodland Scenics foam roadbed has worked well for me since 2014.
Like any other material there are definitely tips & tricks for success.
To adhere the WS roadbed to the foam base I use GE Clear Silicone Caulk. There are two (2) Types:
- Clear Silicone I is their “standard” silicone caulk.
- Clear Silicone II touts that it is, “Rain-Ready in 30 minutes.”
Both require a caulk gun for application.
I really haven’t seen a huge difference between the two. They both take 24-hours to fully cure.
An advantage of using silicone caulk is if you need to remove the roadbed after it has fully cured it comes up without damaging the roadbed or the foam base.
Removing the silicone residue is as easy as peeling up the cured silicone. The foam base is actually cleaner after this. Trust me on this one, I know.
To get an even layer of silicone caulk I apply a thin bead down the centerline. Then I use a 2-inch plastic putty knife to evenly spread the caulk.
After placing the roadbed I use 2-inch “T” pins to hold it in place and allow it to cure for 24-hours.
If there is any excess along the edges it cleans up with a paper towel.
To set curves I split the roadbed down the centerline.
Next, I place “T” pins along the centerline on the foam base as a guide. Depending on the sharpness of the curve I might place “T” pins as close as a few inches apart.
Again, I place a bead of silicone caulk down the center of the halved roadbed and spread it thin with the plastic putty knife. If there is any excess caulk I leave it on the centerline.
I prefer to set the inside of the curve first by aligning it to the “T” pins set on the centerline.
Once in place I use more “T” pins to hold the
