What kind of adhesive is best to use to bond wood to plastic?
Thanks Pennsy Ed
Thanks Pennsy Ed
Well, that dependshow strong the bond should be.
For simple applications normal hobby glue (usually dissolved celluloseacetate in acetone) will do.
If there will be stress on the bond, you could try acrylonitrile based glue (1 second glue and similar tradenames).
Actually wood and plastic are both relatively easy to bond to, as compared to earthware, metals, glass, etc.
Good luck
Egbert
I have had good success bonding wood to plastic using regular Ambroid or Testors plastic cement. The kind in a tube, not the liquid plastic cement. Been using it for years to fasten plastic wall panels and floors to wood bracing and reinforcement.
I’ve had good luck with “GOOP” for gluing dissimilar materials.
5-minute Epoxy, or “Goo”, are the 2 I usually use. Testers should work well also. Joe
Gap-filling ACC works too.
The one thing I have found to be important, regardless of glue type, is to roughen up the plastic suface which the wood is to be glued to. This can be done with rough sandpaper, or using a hobby knife or razor to create some surface scratches. Then immediately after gluing, to use some kind of clamps to hold everything in securely in place.
