Anyone know any info about these and where I can see some pictures ?
What is this thing? What is the history of it? Anybody know?
-Adrian
It is a Kennecott Copper Corp. GP39-2 locomotive.
The thing different about it is it has a HIGH cab which was built for the Kennecott Copper Corp. in Salt Lake City Utah. These units were built for extra visiblity in Bingham Canyon Copper Mine.
Did this answer your question?
Nathan
Thanks Nathan, The extra visiblity makes sense. Would it have problems going under bridges?
Adrian
If I’m not mistaken,the pit to smelter right of way has no overpasses just grade crossings
marty Ca.
Even if it was built that way on purpose, it looks kinda’ like the result of a “shotgun wedding” between a GP39 and an SW1500.
well when you buy 28 loco’s you get them the way you want. they had the high cab because they were an engineer only operation. there was no one on that side of the cab.
marty Ca.
Hi David, actually Kennecott Copper sold 9 units to MKT, which was merged into UP. I also had one of the units at the yard in Roseville, CA…
Marty,Ca…
Hey David and Marty,Do know what the Numbers are on these locos?
Thanks,
Nathan
At least one of these units was aquired by uncle pete. The high cab was converted to a standard one. Some times it can be seen toiling around Denver. It is heratige is very odvious.
David
As of 2001 my roster shows these as UP 2350-2358, but with the renumbering I don’t know. Did they put new fuel tanks on them or do they still have the high clearance ones?
Well Darn, UP didn`t keep those numbers the same as when they were Kennecotts.
