Hello, I am working to construct an HO scale Campbell Sclae Models grain elevator. I am using the Home Grain Co. elevator at the Ukrainian Cultural Heritage Village outside Edmonton as my inspiration. The engine house of the Home Grain elevator is clad in tin panels - I assume for fireproofing. Can any of you suggest how I may replicate that cladding on my model?
Thx in advance for your suggestions.
D
Side note to the moderators. I accept that Kalmbach will monitor and restrict my activity until I have proven myself worthy. I previously posted under the username da1 but for some reason that username stopped working and I was forced to create a new username. Whatever, do what you need to do.[%-)]
I would expect that quick, cheap and fireproof all played a roll in the choice of materials. I made some roofing panels out of aluminium foil rubbed over an old flat compter cable. I have also used N scale corrigated roofing for HO, I liked the looks better than when I tried HO scale.
I tried looking for a better picture, but could not find one.
IIRC the tin cladding is applied in ~18-24" square sheets. I have seen the same cladding on the inside of elevator engine houses. I may need to travel out there to get a good picture - it’s just down the Yellowhead from here.
Answering other suggestions, the cladding is not corugated, it is square flat or embossed panels.
Okay, so I’m sharing with Mrs. 29 my lament of the tin cladding. She reminded me that I’ve been collecting books on Alberta grain elevators for a decade. So I consulted the books and found this very good picture.
This photo is from Heritage Park in Calgary. I seek to replicate that tin siding.
Lots of feedback on corrogated panel, but you are looking for something to simulate the flat tin sheets. This is easy using craft paper and a pounce wheel, with some paint and weathering effects - the method is described in a number of the Fine Scale Miniature kits, to simulate tin roofing.
Here’s a picture of the material (basically construction paper) and an excerpt of the instructions:
The effect is pretty convincing IMHO:
Key is a heavy wash of rust at the end, followed by more alcohol ink wash - the effect is subtle to mostly wash off the rust color while leaving the right amount of residue
