I have not received any compensation for writing this content and I have no material connection to the brands, topics and/or products mentioned herein.
I don’t normally brag on Black & Decker tools but their little VPX drill is very powerful and has a removable battery so its easy to swap the battery when highly used, It gets into very tight spaces.
This morning I needed a 1” hole in my layout through ½” plywood. I used a 1-1/16” hole saw and the mini drill did it easily.
My wife bought it for me about 5 years ago and I’ve only used it for drilling small holes, this morning it earned its keep.
The CDS300 is the most worthless tool I own, unless I would need to drill holes into butter. It does work good for winding #28 or #30 wire on to small spools (very small spools), 180 RPM.
Honestly I have one of those little drills I would never buy one but it was given to me for a Christmas present. It stays in the junk drawer and once in a while it comes out for a little task.
In my truck on the other hand I run the Milwaukee 20 volt lithium-ion fuels with the double wide batteries.
There’s so many add-ons to these tools, every time I think l’m getting close to acquiring the last one they come out with two more
One battery charge lasts for a better part of the week with consistent use.
Buy a Ryobi, with X-mas coming they will be cheap, like $79 with charger and battery and if you want a saw and two batteries and drill, last year they around $100. All my battery tools are now Ryobi and have even used the sawsall on a real construction job before the newer batteries came out.
