Ground Throw For Atlas CustomLine Switches?
Does anyone know which of the ground throws is good to use with Atlas CustomLine Switches?
Thanks
Jim
Jim;
Any of these can be made to work; I would go with the longer travel rigid, and fabricate the spring as part of the linkage.
Caboose Ind 202S
Caboose Ind 218 with multi-fit ends
BOB H Clarion, PA
CI 202 (Sprung) works for me. [:)]
I might add that it easy to make “linkages” from piano wire (available at your LTS) that run under the switch if you need to place the throw opposite the throw-bar or further from the track.
There is a nice description of installing a Caboose Industries Ground Throw on an Altas CustomLine turnout in the NMRA ‘Introduction to Model Rialroading’ pages at: http://www.nmra.org/beginner/ground_throw.html
202s works every time, with atlas #6 no modification necessary, with #4 all you have to do is make hole in throw bar slightly larger.(code 83 track)
I use the #218 ground throws for mine. I am using code 100 Atlas Customline switches now and I use the fitting that has a little pin on it. I cut most of the throwbar on the switch off and drill a hole in the solid portion.
Reed
