[8] I have a small Lionel train set & always wanted to suspend the track from ceiling/along the wall… any quick, easy ways to do it…
Mike
Mike
Mike, my suggestion would be to use those L shaped shelf brackets attach to the wall studs and useing plywood with homesote or foam for the tarck to rest on. 1X4 facia(spelling) hides the brackets. Just make sure the brackets are securely screwed into studs, running trains do create a lot of vibration. Ken
hmmmmm wonder if the wife would like that!!! hahaha trying to think at the local hobby shop… think he was using hooks & wire and suspended it…hmmmm maybe I better stick to the HO layout…
If you really want to hang it from the ceiling you use these from closetmaid,
http://www.closetmaid.com/pod/RafterShelf.cfm
bill
