and I´m wondering how tall it is. I need to know the height up to the deck and railings from the bottom of the boat so that I can plan my post height and position of my Huletts.
Any info on the height to the highest point would also be appreciated but not necessary.
I’ve already e-mailed Sylvan but wasn’t sure if they where one of those companies that seem to misplace e-mails rather then replying to them. So I thought I better ask here as well and might get a quicker answer. I’m building the section as we speak so I’m eager to know as fast as possible. You know how it is. [:)]
So anyways, thanks for the suggestion and the email address, I apreciate the help and the effort tremendously. I’m glad to hear that Sylvan is very responsive. I got one of there Laker class steam ships. A very nice model so I expect this to be just as great.
As I said, I’ve dealt with Sylvan twice and they treated me well both times. One instance I broke a part and asked them if I could purchase a replacement part. The other instance I was missing a part. In both cases, they sent me the item for FREE. The missing part was actually a rubber tire. Sylvan sent me an entire set of 6. [:O]
Magnus, if you don’t hear back from them in the next day or so, just send them another e-mail. They are a small family-owned business. So, it wouldn’t be entirely out of the ordinary if “family” things come up sometimes and they don’t get to inquires as quickly as usual.
Anyhow, I look forward to seeing pictures of that ship when you’re done assembling and painting it.
I have a Sylvan Great Lakes ore boat that I modified, but if you want, I can take some measurements of it when I get home tonight. What are you mainly looking for…height of the hull in the mid-section [for hullets]? I’m not sure what you mean by “post height”, are you referring to forward and aft posts with the running lights on them, to determine bridge clearance? Mine are customized so they might not be accurate…
YIKES ! $300.00 for a plastic kit of a boat?? and can those dimensions be correct? 36’’ long (3 feet) that’s a pretty massive addition to any HO layout. Also try looking around on a site for plastic model boats, pretty sure you will come in way under $300.00.
Correction: It’s actually resin rather than plastic. I’ve only put together their small resin car kits. However, they make a very good quality product. Should turn out quite nicely.
In fact $300.00 for a 1/87 ship model is not expensive at all, it is rather cheap. Also 36" long for a ship model of a Great Lake Freighter is rather short. A full length HO model of such a vessel would be over 7 feet in actual length.
At the club we scratchbuilt a model of a small containers ship see below.
Since the pictures were taken more work has been done on the scenery.
The ship was built from plan of a small container ship that could carry 1100 containers of 20 feet. It is 6 actual feet long, we had to cut 100 feet from its real length in order for it to fit in the space available. We also had to reduce the eight of the structure by one floor.
Why would you expect it to be cheaper? These are highly specialized kits that are prototypical only for a small geographical area (Great Lakes) and are special purpose vessels designed for a single commodity. They’re not going to sell in the thousands (or hundreds for that matter) per year.
Given that the prototype is 380 meters long and the model only 1 meter (more or less), that model is at a scale of approsimately 1/380 ( or significantly less than half the size of N scale). 'Course it is “RTR” and not a kit. Hmm. I could get a DPM brass engine for that price.
A lot of the crane 's components are scratch built. The basic main derricks are 2 IHC intermodal crane kits that i cut one end off and filled in with styrene. I used bits and pieces from other kits so that the lifts move up and down and from side to side and can pick up a container from the ship if need be. Both derricks can also slide along the pier on code 100 rail that I embedded into the “concrete” next to the railroad tracks.
I would apreciate in case Sylvan takes it time to answer.
About the “post” that is a typo on my part, sorry. I meant port height. Basically I want to know how high above the water that I want to place my quay (I lost that word from my English vocabulary when typing originally).
I need to work out the height so that I know in what position to model the Hulett unloaders that I got.
I would would be very happy if you could give me that info.
I don’t think that is very expensive at all to be honest. It’s a one time investment and you don’t need many of them. It’s not like the coal hoppers and ore jennies needed to receive the cargo. Nor are they engines which might cost a lot more for just one engine and we all end up buying several, atleast I do.
About the length, they are very narrow so they don’t eat up to much space. I will have to large boats of this size on the layout and tugboat. I got a Gato class submarine built up that I’m considering adding as well that is roughly 4 feet as well. But they are all narrow! So they make excellent industries. The Laker class tramp steamer I got make an all round industry that can pretty much receive any cargo and thus is a lot of industry in a small space, just 3 feet. It can receive either oil or coal as fuel. It can receive all kind of boxcars with all kind of materials.
This ore boat can be lengthened and I’ve order two additional sections bringing the boat up to 140 cm. Which is not overwhelming in any way if you ask me.
Will do, it will take some time but I’ll post some pics when it gets here and starts getting assembled. Need a new camera too, the old one eats batteries, two pics and then they are gone.
Ah…OK, now it all makes sense! I’ll measure the height of the hull from the waterline, and the height of the dock from the water.
Since everybody else is showing pics of their boats, I’ll show mine. Here is a full-length shot of the Marquette taken in 2005, when my current layout was still under construction. NOTE: It has 3 hull extensions, and a “false bottom” to make it look partially empty.
