just purchased a heljan 3 stall 803 roundhouse extension. it’s supposed to come with the center of the three sidewall sections extending higher to match the higher roof, but the box has three lower sections with no higher center section. but the longer windows for that higher section are included.
i just saw photos of an open box ebay similar kit and it also lacks that higher section, just has 3 lowers. what gives?
I built this kit back in 1995. You already have the two outside walls with the #802 kit, yes?
The add-on three stalls will only have three back wall sections, three door arch sections and three girder supports and roof panels (12).
I’m not sure what you mean by “center of the three sidewall sections”?
This is the one I had until I replaced it with the Walthers Modern Roundhouse:
Roundhouse4 by Edmund, on Flickr
I made roof sections removable.
RH_4 by Edmund, on Flickr
Plus the floor sections, too:
RH_3 by Edmund, on Flickr
Good Luck, Ed
Thank you for your generous help, Ed! I circled the missing side section in red. The kit (which was advertised as having missing parts) includes an extra shorter wall section instead of that taller one, and the back sections are missing but at least the extension shed is all there so I will only have to kitbash two back walls and that taller circled section which was so charming it’s what led me to buy the kit. At least the taller windows are in the box.
Goes to show you no matter how much you study the photos and think all the parts LOOK like they are included, the only proof is when the box is in your hand and you see what’s really there.
All the best, Rob
Hi, Rob
Well, you know, the side walls which are one piece, are part of the 602 Three stall roundhouse. The 603 “extension” kit is simply to add additional stalls between the side walls, thus the 603 kit does not include additional side walls.
The “extra” shorter wall section is probably the wall that lengthens one stall which is an option with this kit. Did you get the instruction sheet?
You’re a little late. I had offered the 9 stall roundhouse shown a while back and had one person interested then they changed their mind. To the styrene recycler it went after I stripped out all the usable parts.
Enjoy building your kit.
Regards, Ed
thanks ed, the box says 803 and it is the extension set. the instruction sheet shows that raised section I circled. (the one that meets the raised roof)
a kitbashing we shall go!
thanks to you ed i think i figured it out. what is missing is the one piece sidewall running the entire length front to back with a higher middle. the three shorter sections included in my box are the three back walls, because their top edges are horizontal to match the rear roof edge. am i correct?
or are you saying the 803 was just a CENTER add on with no side walls at all? now i am thoroughly confused. next time i will spend a little more and buy a complete kit. -rob
ok i can now put this puppy to rest. i looked hard at photos of ebay 803s for sale. no sidewalls are included and the item says mint new condition. the 803 goes between two finished sections like ed said, thanks ed. what threw me off was the tall arch windows for the middle of said sidewall are included which made me ask where’s the rest. i guess all the windows are molded on the same sprue so they throw them in. -rob
Hi there…I am happy to come across this old post. Do you have any pics of the 2 outbuildings attached to the back of the roundhouse? I am also on a crusade to scratchbuild this great kit. Thank you , Marty
Sorry martygto I have no photos best bet is to search ebay for seller photos using the 2 kit numbers —rob
Thank you! I was able to complete the project.
