Help and advice with yard design
Here is a simpler concept that includes a turntable as several have suggested. Since most of my steamers are 15" or longer I would need a big turntable so 18" is shown. The turntable does take up a good bit of territory.
The track at the bottom that made up part of the wye is gone due to the turntable space constraints. Instead the passenger track is at the top. I also eliminated turnouts that led to short-ended tracks and focused on how to keep locos from being trapped when pulling cars into the yard. A small switching loco might be handy to move the cars to storage instead of running around but that would not be a bad thing. Track 1 is shown holding my passenger train including a 4-8-2 and tender. And I put some 50’ freight cars on the shortest track to get a feel for storage space.
I think the general concept is more workable and worth taking some time to develop. What do you guys think?
A double-ended yard would have been nice to have but it would have taken up a huge part of my area, defeating my vision for the layout.
Just for fun I pulled up the google map for the Nevada Northern since that is where the sum total of all of my prototype yard experience is. There are dozens of storage tracks but almost all of them are dead end with few run-arounds. I know we shoved and pulled cars all over the place for a couple of hours to get things sorted out. At the time it was very confusing, especially without a map of the “layout”.
Greg all of my trains and locos are now “stored” on the sidings and the reverse loop just like you describe. They all fit easily without affecting the mainlines but having that many out there is not ideal for obvious reasons.
Walt,
I like this revision, too.
While a lot of the critiques would certainly apply if the prototype was a big consideration here, sometimes a model RR is just a model RR. Nothing wrong with paying attention to the prototype, if that’s your thing. But I think the P word has been so drilled into people’s heads that it has become the box we sometimes need to escape in order to accomplish our goals. While well-intentioned, I think Walt’s made it clear he has some other goals beyond prototype modeling and there’s nothing wrong with that, either.
It may be just me, but I’d be more comfortable looking at it if tracks 6-9 stayed parallel with 1-5. Other than that, it looks like it should serve the requirements you have defined.
Thanks Mike, it sounds like you understand. I’ve always tended not to follow the pack, and to go down roads less traveled. Its always worked for me- both personally and professionally, and especially with hobbies. I have a bookshelf full of plaques and trophies as a result of “doing things my way”. Railroading is still relatively new to me but why stop now?
Carl, once I decide the general concept is good then I will start looking at how to fit in some structures, etc and that may alter the track positions a bit. I should be able to fit in a switching tower and some small buildings, and maybe a loading platform. And I need to look at what space will allow for steam servicing.
Even if it is track-heavy and not prototypical, I still want it to look nice, and more or less period-correct once completed. So that will drive some decisions.
is the intent to pull a train into a yard track and turn the locomotive?
Assuming the orange car on track 5 is the locomotive, is it trapped until the cars in the train are sorted to other tracks or will the entire train back out of the yard onto the mainline?
track 9 could be used for arriving trains, allowing the engine to escape to the turntable, but it doesn’t look like the length is long enough between the turnouts and the lead at the end is longer than needed.
nothing wrong with being radical, but don’t you still need to be pragmatic?
Pragmatic is a good word! That is what I am looking for.
The orange car to the far right on track 5 is not a loco, just an orange car. If it was a loco than it would have to shove the cars back to get out. Not necessarily a problem if I just wanted to park a train like that, just saying.
Yes track 9 is meant to handle incoming trains. Once the loco is released it can go to the turntable, or go back through the bypass and hook up to the train at the other end to sort/move cars onto the sidings. Or I could dedicate a switcher for this duty. If the train is very long then getting to the end may foul the blue mainline but that is not really a big problem. Remember I am a lone wolf and not planning on any other experienced operators to run trains with me. So there would be nothing running on the blue line while I am switching anyway.
Walt, build your layout the way you will run it for your own satisfaction. It is ok to ask for opinions and sift through the ones that make sense and discard those that don’t. I build my layout based on no prototype, all staging is visible (gee it is called a flat switch yard) and build trains out of that. Whatever you decide on, enjoy what you are building.
Yeah that’s the ticket. But I do appreciate advice from those experienced here- reading through all the threads and posting specific questions has kept me out of trouble more than just a few times.
I just realized last night that the Walthers 18" (130’) turntable went out of production a while back and there is some scrambling on e-… to snatch up the few remaining. I searched around this morning and found a store that had one in stock for the regular discounted price. So went ahead and grabbed it. Better than the e-… scramble.
That’s the one of the reasons I wanted to confirm the basic concept now, even though it will be some months before I am ready to finalize the design and start building. Not only does the final design have to work OK but the critical parts have to be available in order to build it.
Thanks guys. I will post an update when I get ready to start construction.
One thing to consider is that if you really want to have a storage location more for car display than classification, consider either a large industry, or an interchange yard. The orientation of the track plan is perfect for a large interchange, heading off perhaps under a road bridge at the end of the benchwork. It could be realistic to include some sorting tracks for locals and an engine terminal if this is a major traffic source for your railroad.
Maybe this will help, a diagram of the part of the basement that my layout is in. Much better and bigger than a spare bedroom, but not as expansive an area as many of you guys have. At least I have a bathroom, a shop, and also a handy outside patio to cut lumber on.
This was a band practice room years ago, and I still have my PA system, guitar amps, etc set up just for messing around by myself or with another guitar player. I have a lot of gear and the music area is really tight with the layout as it now is. If I expand further then I would need to find another location to set up the music gear. My wife would come into play if I go that far- I can do anything I want with this space, but once I go outside of it…
An interchange yard has been mentioned in other threads. Sounds interesting, but not sure what it means and how it would be set up. Remember I am not a RR buff. One thing for sure, the yard/storage I have planned can’t go much further too much further to the right.
You can see some of the minor revisions I’ve made to the yard plan. I’ll continue to play with it during coming months.
Hi Walt,
I am not an “old pro” and I admit I have torn down about six layouts, in the bench work stage, until I finally found one I like for all the reasons many of the good people here mentioned. My very first layout was scenery based tailchaser with my son, after it was “done” we both got very bored with it and it died a slow death.
This time around I want not only the scenery challenge, but kept in mind operations so on long winter nights I can operate my layout if I just want to play without always working on something. My layout n
The turntable arrived and I mounted it on a test platform built from scrap lumber to make sure that it works and to get a feel for permanent installation.
I’ve seen quite a few posts on various boards from those trying to figure out how to make the Walthers DCC turntables work right. This one is functional but it does have a bug- after a couple of cycles it sometimes forgets to compensate for the distance from the 0 point to track 1 when indexing to track 2 and the user set positions. The bug is very repeatable though, and by programming a second point for each track location it is always possible to get it there. If anyone has a fix for this let me know. Other than that the turntable works fine.
This is the first turntable I’ve played with and getting it mounted securely so that the lip height is consistent looks like it will be important. It sits just a bit higher than the ties on the Shinohara track I am using but at least the rail height matches. The screws for mounting it from underneath are about useless though. I think it would be better clamped down from the top somehow.
I am not thrilled with the finish- it has that “plastic” look that I am avoiding everywhere else on the layout. But I am not up to building a big turntable from scratch. Maybe I can dress it up somehow.
Also considering how to construct the yard. Except for some sidings that are directly on foam all of my track is on ply subroadbed and cork roadbed. For the yard I have been thinking of sheet cork on ply. That would give me opportunity to drop the ground level on the side of the tracks in places and provide some sound deadening. And it would still allow simple installation of Tortoises and wire drops. Any do
Is your yard large enough to store all your rolling stock, plus a little extra for future purchases?
Will it have enough room for all your locomotives?
If you are not interested in ‘operations’ and you have to reach in and retrieve something, so what. It’s a fiddle yard. You can build your next train on the main-it’s your layout. Besides, how many trains will you be running at one time?
What ever you decide, you can still make it look nice.
Just leave enough room for your fingers.
I would paint the edges, sides and leave the bottom for now. The plastic has that metallic look so use one of the plastic paints and get it grey/brown, kind of the used look. After that is done then you can play around with “gravel” on the bottom. A light coat of different ballasts would be good. I would start with a dirty looking white then at different add drops of grimy blk. to represent grease and oil at locations where they would be normally from a prototype, in line with the roundhouse tracks and other building tracks especially if you have an engine shop. Have fun.
As designed now the yard tracks will hold all of the freight cars and passenger trains I have without a stretch. Loco storage depends on how many tracks I fit in off the turntable. If I keep on buying rolling stock then some of it will have to come off or it will migrate onto storage on sidings, but that seems pretty typical.
Yes this will be at least in part a fiddle yard. Spacing is 2-1/2" and I figure most of the “fiddling” will be on the outside tracks. And I have access to both sides.
As for dressing up the turntable I have gotten pretty good with an airbrush and can probably do some good things with the pit. The bridge is a bigger challenge but I am not losing any sleep over it.
