You say I dont have enough room, can you be more specific as to what you mean applying it to my layout and where instead of being general in your statement? I used that guide and thought I left enough room to accommodate this. Also how can you tell with that pic that has been re-sized vs what I can zoom in on in AnyRail?
Well I started to layout my track to mark it for the roadbed. Just wanted to post a pic of the pinwheel that was suggested earlier in the thread by Paul. It was tough at first to get it right but it worked out great and my autorack looks good maneuvering the curves into the yard.
Thanks Motley. Actually it is 1/2" plywood. I painted it mainly to kinda seal the wood up so it wont soak up to much humidity in the summer time even though I run a dehumidifier. Just a tip a painter told me. The top will all be covered with ground scenery, roads, buildings etc, so you wont see any of it.
spacing is the distance between center-lines; i am glad you do not use 2 inch spacing…but 2,5; no long cars colliding. I gave you the appropriate NMRA information.
Thanks Paul appreciate the kind words. I am going 2.5" on all center to center track whether it is straight or curved. I have fat fingers, so that will allow me to get to each track with out knocking over any other trains.
