Merry Christmas!
Anyone know how to take apart a Proto 2000 2-10-2?
When I bought mine off Ebay, front headlight didn’t turn on, and Ive checked the wiring and the decoder, it must be something inside the engine that’s causing the problem.
Check to see if the front boiler plate will pull off. Some boiler plates are press fit into the boiler and can be removed with some careful prying. I know my BLI locomotives are like that and the front headlight lens on my Proto 2000 0-8-0 is removable.
tstage - the headlight is lit via a clear pastic light tube(?) thing that directs an LED thats housed far inside the loco to the headlight. Not as easy as it looks.
gmpullman - thanks!
