I need help removing the shell from athern blue box gp-9. Any drawings or diagrams or tips would greatly be appreciated.
Thanks
Mike
Thanks
Mike
Try this link, pry the shell just a bit buy the fuel tank, there are 4 tiny pins that just stick out that hold the shell on, it should come right off then.
thank you for the help. Where can I find replacement hand rails for it?
Try this hobby retailer, they have decent shipping cost, and a good turn around.
http://www.discounttrainsonline.com/ho-scale-model-trains.html?source=overture
i scratch build my hand rails out of steel wire or paper clips if needed and the file them in order to get a grip for the paint job
First Athearn has discontinued all metal handrails even for the GP7…I suspect handrails from the Walthers GP9M will fit seeing the old Athaern GP7 handrails fit the Walthers GP9M.
You can find a link to ChooChooAreUs at the web page listed below. They have many older Athearn Parts. I am not sure how long they will availab leseeing the parts are becoming hard to find.
http://www.hoseeker.net/athearnmicellaneous.html
Hope this helps.
Larry
