Hi,
My name is Ricky, and I frequent the Model Railroader forums, and occasionally the Trains forums. This is my first post here.
A friend gave me an Lionel O-gauge set, that included oval of track, two Lionel Alco PA locomotives, one powered, one not, in Amtrak paint, and passenger cars.
Included is a photo of the locomotives.
It also included a power pack and transformer/throttle.
Unfortunately, they gave it to me as it was not functioning when they got it used from another individual. (They had got it for their boys, but when it wouldn’t run, they said I could have it, to display with my trains.)
The power pack does supply power, but no lights, motor or sounds from the locomotives. (They do both have onboard sound, as I have popped the shells off to check wiring, and was surprised by a speaker inside each unit, the wiring appears intact, as best as I can tell. No obvious broken parts or wires inside, motor contacts appear intact as well on the powered units trucks.)
Before opening the locomotives, I had cleaned all tracks and wheels, when nothing worked, I checked to see if there was any power from the controller, and there was, but maybe wrong voltage?
With the onboard sound, must there be a special controller? What voltage would they need to run? Or do I need to look elsewhere for the problem?
I would really like to get these to run, if possible, so as to give them to said friends boys, who are now 9&7, for them to enjoy. I just am a little lost when it comes to O gauge equipment, big difference from my HO scale ones! Anything I am missing?
