I have a couple of old Marx Wind-up trains and a loop of two rail Marx track. When I wind up the train and then hit the lever to release it, neither of them moves around the track. The wheels will spin and the bell will ring if I lift it from the track. Upon inspecting the train pictured below, I noticed that the one drive wheel spins on it’s shaft. The wheel rotates on what should be a splined shaft. Any ideas on repair or should this just be a display piece?
If it is that loose, the wheel should come off fairly easily, then
carefully use a punch or chisel to put a dimple or notch on the axle,
then carefully re-install the wheel. If it’s a piece more for show and
only occasional running…shhhhhhhh, I put a small dab of Zap-A-Gap
(crazy glue) on it. Just don’t tell anyone, that’s not in the repair
book.
(Marx??) track. When I wind
up either train and then hit the lever to release it, neither of them
track. Upon inspecting one train,
I noticed that one of the drive wheel spins on it’s shaft. The wheel
rotates on what appears
to have been a splined shaft. Any ideas on repair or should this
