I’ve got several—well more like a dozen—assorted power supplies for providing juice to various DC electrical functions around the layout.
I like to use these CCTV camera power supplies because everything is there that I need, filtered DC, auto-reset overload protection and a handy barrier strip for hookup.
Sometimes I really don’t know how close I am to reaching the load capacity so I decided to look for a handy panel meter.
The only thing lacking is a way to check on the load and output. I don’t want to have to disconnect the load and use a VOM, I want to monitor the power at-a-glance.
Before long I came across this little guy at Amazon…
It’s easy to wire, has a shunt that will read up to 10 amps at 4.5 to 30 VDC and both voltage and amperage can be adjusted using little pots on the board, if you have a good reference meter. This one, as delivered, was within a few tenths so it was good enough for me. It has a snap-in bezel but I wasn’t going to get that fancy so I just Ty-Raped it to the outside of the enclosure.
What model power supply is that? I see different models all over the place in price, if the price is right, they could eb very handy.
You need to get a nibbler tool, then you can stick the meter right in the cover. And get some SLA batteries - if that model power supply supports it, many of them do, which would keep things going even if the power line drops - lol no lights, no fridge, but we’re running trains!
This one is Altronix BH12DC16CB, but as you say, they are priced all over the place. I buy used ones from ebay and I have a few of the cheaper knock-offs, too.
Pelco is one of the top-line camera brands, Altronix is a step down. There are hundreds on ebay, you just have to shop carefully. I don’t think I paid over $25 for any of mine.
Many camera systems are 24 VAC so you have to watch for that, some of the power supplies are AC/DC selectable.
As I mentioned, for our use they’re great since they have individual circuit protection, most have 8, 16 or 24 pair terminal strips and everything is enclosed in a nice box.
Yeah, for the signal system it would be great to have battery backup… especially for my engines that have keep alive and will keep running during a power outage!
I just got a nibbler, I was too lazy to do the sheet-metal work. Maybe I’ll borrow the Greenlee punches from work… IF I get ambitious. Maybe ganging several of these on a remote panel might be a better way to go?
Mel, the one you link to looks like it needs an additional supply power? The one I got only requires the three wires with the load minus going on the yellow wire and, of course, DC plus and minus on red & black. Still, those look like an economical way to go.
I see that they have sold out at Amazon since I posted this thread but, as Mel points out, there are others. Back when I was building DC throttles and layout power supplies, analog meters were a pretty penny. [2c] [2c] [2c]
The camera flash exposed the unlit segments. In person everything is black on the panel. The big blue digits on black looks really cool and is super easy to read. My layout is RailPro so no RMS needed. The track bus readings (left meters) are accurate with the little meters. The Control bus (center meters) is for all things electronic on the layout - clean no spikes bus. The Accessory bus (right meters) is for noisy inductive stuff like motors and solenoids.
Do the math - RMS voltage of a square wave is the same as peak. This is different from a sine wave. An RMS meter which adjusts the measured AC voltage based on sine wave input will give an incorrect reading on DCC. This is why the readings on the cheapy meters is usually right. A high end RMS meter like a Fluke is usually designed to read properly from sine, square, and triangle waves (at least one of mine is) so those should give proper readings as well.
RR_Mel, there’s a bit of warnings here about customs. Did you have any surcharges or such from the feds? Note: A. Import duties, taxes and charges are not included in the item price or shipping charges. These charges are the buyer’s responsibility. B. Please check with your country’s customs office to determine what these additional costs will be prior to bidding/buying. Thanks. Ken
“Packages whose declared value is under $200 ($100 if being sent as a gift to someone other than the purchaser) will generally be cleared without any additional paperwork prepared by CBP.”
I’ve never had a problem buying packs of RC servos (I use those for my turnouts) from various China sources on ebay, and I recently bought a nice multimeter from some crazy Aussie bloke which was around $100AUD and that came through with no additional charges or fees. Oh and a few times I’ve ordered circuit boards from Hans Deloof in Belgium with no problem.
