Which one is cheaper? Like Cacole stated, ‘‘they are both probably the same thing’’, made from Lampblack. Durable, waterproof,smearproof. I used to use the India Ink with shellac in it for Machine design drawings, never used the other. Btw, the chinese came up with the India ink formula back in 220-230 AD. and a lot of their works are still around…add non-fading to the list above. LOL.
Ha! It even mentions model railroad use for staining wood. So at least one model railroader edits Wikipedia.
Also interesting - dried India ink is somewhat conductive. Makes sens, since it is made with carbon black. I need to measure the resistence of some lines of it, there may be a use for resistor wheels.
Dave, I think that is what I remember also, reading india ink wash articles in the past. It was pure black. I can’t remember if there were other things that made those authors/modlers recommend India ink specifically or not…
I knew there was something that made me ask this question in the lst place…
On Amazon the description for the India Ink includes a semi-gloss finish. The drawing ink (Black Magic) dries with a matte finish. Does adding alcohol to our wash mix automatically dull up the semi-gloss aspect?
I could also use a reminder of a typical alcohol to india ink ratio subtle washes should be.
I don’t think it’s that we dilute with alcohol, although that helps - it’s more that the wood absorbs the other components of the ink, including the binders and fixers that give it a gloss finish, leaving just the carbon black deposited on the surface of the wood.
Without alcohol the wood couldn;t absorb enough, plus no dount the alcohol also helps some of the carrier evaporate as well as be absorbed into the wood. Besides, we only want a little of the black, to make things look smudgy and old. Like when your fingers are just a little greasy - when it’s in the skin but not coating it, so your finger isn;t black with grease but just slightly discolored.
Thanks RGengineoiler, I’ll look next time I’m in the city. I’ve got some coming from Amazon for the lst batch-maybe the only batch I’ll ever need…we’ll see.
What’s the usual ratio for an alcohol/india ink mix? Again I’d mostly be using it on styrene painted with primer and acrylic paints. I have one wood kit I’ll use it on eventually. “Sweaty Betty’s Cafe’” (Bar Mills) but that kit will be for “down the road”.
Jim, I adjust according to what I am doing and test as I go. I have never had any set rule as I use the mix for different things such as scenery and some weathering of wood etc. Doug
