What is the history of the Proto engines? Reason I ask is the color of there boxes. I just got a BL 2 Monon that box is a brown green color. When I pulled the chassis it looked all most like a Athearn Blue Box. Only thing I found diffrent was there is a gound plug in the chassis and chassis coupler mounting point is up side down which is a good idea.
Box says it has a 5 skew pole motor, but looks just like all the Blue Box motors I have. In fact it pulls the same power as my Super Weight and pulls the same drag as my Super Weight Athearn F-7. Did Athearn make make this engine?
It pulls more power than my other Proto 2000’s as well. I have the following.
A and B powered Proto 1000 Erie Bulit, see though small boxes that is gray.
A and B powered Proto 2000 E-6’s box is blue
A E-6 powered and has a gray box.
On the E-6’s the only thing driffrent is the coupler box. E-6 with the gray box has a screw that hold the lid on. But same power needed as for all the Protos excpet the BL 2?
BL 2 is all so light in weight, only 14 OZ’s. Super Weight comes in at 16 OZ’s.
As far as parting out the BL 2? I must say I like it a lot and on the hunt for another one.
Cuda Ken
