HO Railroad Crossing Signals
Are there any railroad crossing signals that will work on a DCC layout that can be automated.
Thanks in advance.
Crossing Signals are independent from track voltage, doesn’t make any difference DC or DCC. I used Logic Rail controllers with IR detection.
https://www.logicrailtech.com/gcp.htm
I recently cut over to using an Arduino and micro servos mainly because I like dinking with Arduino processors and servos.
EDIT:
Link to my Arduino controller:
https://melvineperry.blogspot.com/p/blog-page_97.html
Mel
My Model Railroad
Bakersfield, California
I use Rob Paisley’s detection and crossing signal support electronics, both for flashing crossbucks I got from Oregon Rail Supply and for moving gates and flashing crossbucks from NJ International. The gates also required a single Tortoise machine and dual linkages from Circuitron.
This gave me the remote detection I wanted for what at the time was the best price. I got the circuit boards pre-assembled. There’s a lot of wiring but it all worked great the first time.
The crossbucks are a kit and they require some tiny wire soldering. The gates had a flimsy wire to drive the motion that I had to redesign a bit and rework.
The circuits also will drive a bell, which I don’t have. However, I hooked it up to a REAL crossing bell someone had, and it actually worked. Pretty loud.
This is my East crossing using a Tortoise to operate the gates. The crossings uses a Rail Logic Grade Crossing Pro controller and the gates and signals are NJI. The reason for the delay after the locomotive goes by is that the controller is actually controlling two crossings 4’ apart.
https://drive.google.com/file/d/0B7gZp9MPvrm3OEU3X1NIOElnMTg/view?usp=sharing
The West crossing only has one set of lights for each side of the crossing.
https://drive.google.com/file/d/0B7gZp9MPvrm3M003clFiYVlscHc/view?usp=sharing
The same Tortoise operates both crossings with linkage.
Mel
My Model Railroad
Mel,
since you cut over to Arduino controller, would you consider selling your GCP
Thanks
Nice videos, Mel. Any way to slow down the movement of the gates?
I’d rather not part with it. Kinda like tossing something, I might reuse it someday.
Mel
My Model Railroad
That was video of my GCP and yes there is a pot for controlling the speed of the Tortoise on the board. I went with that setting because that is very close to the speed of the Santa fe crossing close to our house. They come down so fast that once it caught my wife landing on the hood of our mini van.
Mel
My Model Railroad
Yikes! [:^)]
It was worse than Yikes!
The cross arm actually hit right on the windshield wipers and put a scratch in the windshield. I looked out the window and saw the ditch lights. We weren’t in any danger because the gate was 10 or so feet from the locomotive. We waited until the cross arm lifted to move the van fearing it would ding either the wipers or windshield or both.
Mel
My Model Railroad
Were you able to recover damages from the railroad?
The only damage was the 2” scratch at the bottom of the windshield, didn’t hurt the wiper even though the weight of the cross arm was on it. The scratch in the windshield is a reminder.
My wife was looking forward and didn’t see the signal lights come on in her Peripheral vision. When she saw the gate moving she stomped the break. The Santa Fe Dash 8s were really getting after it.
Mel
My Model Railroad
I’m beginning to realize that aging
You need to re-enact that scene on your layout.
I believe the current argot is RR_Karen [}:)][:D][}:)]
Henry
RR_Andra
Mel
My Model Railroad
has anyone used the azatrax D2t-xing for their crossing signal.
I was thinking of purchasing since the cost was less expensive then most others
Thanks
I haven’t used that brand. The Rob Paisley circuit comes with six detectors so it does provide more optimum detection and on-off response in both directions. It’s visible light, not IR, but seems to work well at low light levels.
I didn’t see that the azatrax model supports crossing gates. I think it’s just flashers. The Oregon Rail Supply crossbucks I got are just LEDs, no circuit, and the Rob Paisley circuit flashes them alternately just like you’d want.
With the number of modelers who might like a feature like this, I’m really surprised that no manufacturer makes a complete package, other than toy-like pressure detectors that put the gates down after the train is on the crossing.
Are you still able to purchase Rob Paisley circuit flashes?
Yes, his web site is www.circuitous.ca
For years, it was a different site, but I believe he was asked by that host to change it. He responds quickly to emails.
I second the use of Rob Paisley Circuits, they work GREAT!
Mel
My Model Railroad
