This is just a personal orientation I have to the hobby. I do concentrate on several roads, but I don’t necessarily get all the engines as examples of everything any of them ran in the mid-50’s. As sacreligious as it may be to say so, I don’t have much of a hankering for the mighty Big Boy, although I do model, in a ‘relaxed’ sort of way, the Union Pacific. I like the lines of the Challenger better. So, no Big Boy.
It is similar for the N&W, Pennsy, NYC, C&O, CPR, and ATSF. Not all of their engines get under my skin, so I only purchase those that do. I have a hodge-podge of steamers.
At the moment, and it may change in time, you seem to have the same approach. You are willing to consider quality, availability, and reliability, so the road and type doesn’t matter…it just has to work on your rails. That’s probably good right now. In time as I said, you may want to narrow it down.
So, you asked what other locomotives we could recommend. First, I have no experience with the MTH lines, but their N&W J Class 4-8-4, as costly as it is by comparision, should do well on your layout. So should their Pennsy K4s 4-6-2.
The same could be said for BLI’s versions of those engines…which are somewhat less costly. BLI has another Pacific 4-6-2 marketed or soon coming out. Also a Pennsy 2-8-0 which would be an excellent choice. So would Bachmann’s Spectrum line 2-8-0 if you can find one…a very reliable engine judged by enthusiastic users over the years.
BLI has several Mikado 2-8-2’s, and besides the Consolidation 2-8-0’s I just mentioned, they were the most numerous steamers produced across the board and used for medium-tonnage freights. Passenger, not so much…seldom, in fact, except in pinches, although a few roads did use Mikes on passenger trains routinely. The CPR comes to mind.
Later, as you learn, you might pay attention to deta
