I am some structures that need exterior lights, such as what would go above a loading dock door or an entrance. All I see online are gooseneck lamps and Victorian streetlamp-style things… all of which are too old for the 1980s era I model.
I would prefer the lights be lit via LEDs instead of bulbs.
Anyone know of anything commercially available? Thanks.
I can’t remember the manufacturer of these, but they’re 1.5v grain of wheat bulbs that are already wired. Drill a small hole in the wall, then insert the stem. I wired them together in parallel so they would all have the same voltage using a AA battery.
Thanks for starting this tread! I also model the 1980s and agree that there are too few modern outdoor light options. Perhaps others can provide reasonably priced ideas.
I was going to suggest WEHONEST on eBay but their site is shutdown for a Chinese holiday, along with several others too.
I also use incandescent bulbs and make the lamp shades from washers. I use 2mm 12 volt bulbs and 2mm washers for the shades.
I operate the 12 volt Grain of Wheat bulbs at 8½ volts for longer life an much more realistic 50s look. To make the washer concave I put it on a pice of pine and using a Allan Screw Ball drive tool then hitting it with a hammer.
A few years ago I came up MT when searching for more modern exterior lighting fixtures. While not fancy I fashioned some by capping off the ends of some round & square styrene tubing pieces with 2mm tower LEDs & SMDs for lighting.
The end portion of an 2mm tower LEDs casts less light than a SMD & requires a larger hole, but the fixture size can be a bit smaller in length. The tower LED can do double duty by also lighting the interior of the structure if so desired. Structure wall thickness is a determining factor when using a tower LED.
Regardless of LED type the stryene fixture interior requires a thick coat of black paint to eliminate light bleed.
I picked up some flat LEDs to mount under porch roofs, where the fixture wouldn’t be seen but the light would. I think it would be easy enough to fabricate a fixture from styrene and buy the LEDs separately.
