Ho Scale Road Striping
Started making roads on my layout and now it’s time to add striping. I found white 3M auto pinstriping in 1/16” size for shoulder stripes but can’t find a source for yellow dual stripe 1/16”. Can anyone point me to a vendor? Much thnx.
Tamiya makes yellow tape in various widths. I got mine from Amazon.
I use gel pens, which are available in many colors. With a straightedge and a French curve, I get good road markings. thanks
Try Ebay.
https://www.ebay.com/i/272928130255?chn=ps&var=572124656346
Mike.
I got my yellow and white 1/16” single and double stripe tape at a local automotive paint distributor. Only the packaging had the manufacturers name so I don’t know the brand but I think its 3M.
You can get it from Amazon too.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Dautomotive&field-keywords=1%2F16"+double+pinstripe
Mel
My Model Railroad
There are some very narrow width tapes on ebay, maybe beauty supply shops, too? It is intended for “nail art” for doing pin striping on finger nails. I bought assortments very reasonably. Yellow might be a tough color to find, there are many silver, gold and blacks but if you look you might find yellow.
Example >> https://tinyurl.com/y8kg5wuz
6" in HO is only .0685
I made my stripes by painting the stripe color (white in my case, yellow pre-dates my era) on the road surface FIRST, then mask your stripes, apply dark gray or concrete color then peel up the masking. Makes for a much neater looking stripe.
Just my method that worked for me.
Good Luck, Ed
Mel, thanks very much for that link. That’s exactly what I was looking for (especially the 12’ length). I had seen an old post about this when I was researching alternatives but I just couldn’t find a vendor (Amazon or other). Probably my search entry was off base. Anyway, Much appreciated!
Line-O-Tape has all kinds of colors and sizes of pin striping tape. HobbyInc.com is a distibutor of the tape or you can go to Line-O-Tape’s website.
Thnx Willy for that tip. I already ordered from Mel’s Amazon link but will check out your suggession any future need
Yellow 1/16 inch chart tape is what I use but getting it perfectly even is a challeng.
[quote user=“RR_Mel”]
Mel
My Model Railroad
It’s been several years but I don’t remember having a problem removing it.
Mel
My Model Railroad
Bakersfield, California
