Can some one tell me the measurements on building Ho scale stairs?
Simply use a tape measure or ruler to measure the stairs which you wish to model, then use your scale rule to measure and cut the material you’re using.
While I have scratchbuilt stairs in the past, I generally prefer to use those offered by Central Valley. One package gives you a selection of cut or closed stringers and stairs with or without risers, along with a variety of ladders. Various railings are included, too.
I used the CV stairs on this coal dealer’s bunker:
scale 7 in rise, scale 10-11 in tread depth
If you’re looking for wooden risers and treads, check out the sets from Micro-Mark. Their part # 84059 for the stringers and # 83957 for the basswood strips for the treads. These work pretty slick, and the stinger set includes some forms to hold the stringers parallel while you glue the treads.
Bill
I agree. I’ve tried to scratchbuild steps. With some success, too. But for the trouble it takes, I won’t do it again. In addition to the suggestions above, Plastruct also carries prefab stair kits.
I order some from here
wilson, central valley also has a package od ladders and stairs that might be useful for your purposes.they nare in the walthers cataloge. tuxedo
That’s the ones which he’s ordered, and the same ones which are shown in the picture which I posted. [swg]
