Home made decals.
I’ve tried making decals using an ink jet printer and various brands of “water slide decal paper” with so-so success.
The decals that I make are almost transparent. They don’t stick well. And you can’t use a setting solution on them or the ink bleeds.
How can I make decent decals witout spending a ton of money on specialized equipment?
Thanks,
South Penn
What kind of paper are you using? I use Testors Decal paper. After the ink dries, hit it with a layer of dullcoat so the ink won’t bleed.
I also use Micro Sol and Micro Set.
http://cs.trains.com/mrr/f/88/p/244180/2720459.aspx
Decalpapers.com has excellent clear and white decal paper, which I have been using for over 4 years now. I print with an HP ink jet (mine has 6 colors- black, lt cyan, cyan, magenta, lt magenta and yellow). I print, allow the ink to dry for several hrs, then cover with a gloss clear coat of Krylon Acrylic Color max Crystal Clear. After applying to the model (glossy surface), I then Dull Cote. There is a wider choice of colors I use on clear paper when applied against a white or light gray backround, but when using white decal paper, with any color backround, you must blend the resulting white edges of the decal into your model color with a touch up manually before dull cote is applied.
Cedarwoodron
I will second this. I have made my own decals with great success using several different brands of decal paper and a cheap HP inkjet printer. I tell the machine thats it’s printing on glossy photo paper and dulcote when dry. Give them a day or two to set up and apply like any other decal. I use Micro Sol as my setting solution.
Hi guys
I’ve been making decals for years, many of those years were a learning curve. All decal paper is not alike! Even deferent batches from the same manufacturer are different. I have had better luck with clear gloss on blue paper. Flat finish decal paper never seems to work as good as gloss finish. I have also tried many sealers, most work, some better than others.
When I’m making high profile “Perfect” decals I go with clear gloss finish on blue paper and use 3 thin coats of Testors Decal Bonder for the sealer.
The Krylon/Rust-Oleum and like clears won’t mold or conform to rough surfaces with Micro-SOL or Solvaset, Testors Decal Bonder does. When I’m out of Decal Bonder I use Dullcoat, it’s not quite as good at conforming to rough areas as Decal Bonder but much better than the alternatives. Stay way from Tree House Studio Matte Coating, your decals will look like colored rivers. I haven’t found anything it won’t screw up.
I have an Epson XP-610 3-way printer and make decals from time to time. I use MicroMark ink jet decal paper.
Clear - 5 sheets per pack
http://www.micromark.com/clear-decal-paper-for-ink-jet-printers-5-sheets,7942.html
White - 5 sheets per pack
http://www.micromark.com/white-decal-paper-for-ink-jet-and-laser-printers-and-copiers-5-sheets,7945.html
They also have 25 sheet packs.
Have you tried adjusting your printer settings to a photo paper or transparency paper setting? These add more ink to the paper, and can reduce the transparency problem. Certain ink colors are just transparent, and need to be printed on white decal paper if they are going on a dark background.
I recently gained even more experience with the Evan Designs decal paper since my comments in the thread that JaBear linked to. I have made several more white lettering on colored background decals to replace the ones I goofed up using the “spray can” acrylic clear coat. Once again, the special coating on this paper means that no ink sealer spray is necessary: simply allow the ink to dry for at least 30 minutes before you apply your decals. I made a slight correction on the “oxide” background color from the previous decal set and now the color match is perfect. I just happened to find myself standing in front of a store shelf with Ronson lighter fluid so I bought a 5 ounce bottle to try on the Evan Designs decal paper as recommended by the manufacturer. Wow, this stuff works a lot better than Solvaset on this brand of decal paper. Cheaper, too!
Great paper. Easy to work with. Good inkjet printing results. Full sized 8 1/2" by 11" sheets of paper. $19 for five sheets. No sealer spray needed (save a little money there). Both opaque white background and clear background decals can be made from the same sheet of decal paper! Use an acrylic clear (preferably airbrushed) to seal your model when you want the decal background to remain white or a solvent based clear when you want the decal background to turn clear.
If you are having problems with other decal papers, I recommend trying the Evan Designs decal paper. It really does work as the manufacturer claims and I continue to use it to make great looking decals. Now that I have tried it and seen how much better it works, follow the manufacturer suggestion of using lighter fluid to set these decals. Sounded wierd to me but darned if it didn’t work as claimed.
My only complaint, and a minor one, is that the white backround turns clear when you wet the decal sometimes making it difficult to see whether you applied the decal corre
I think I asked this question before, but how thick are the Evan’s decals? I realize having used them that both MicroMark and Testors decals are not excatly whisper thin, but what about Evans?
What I do like is you can cut the decal out right next to the design (indeed, the tutorials specificallly mention that) as opposed to having to leaving a wide border of decal film to prevent water seeping under the clear coat which in turn causes the dreaded ink bleed.
One of the tutorials (the one on turning the decal clear with canola oil) did mention you can lightly spray a clear coat (dullcoat) like Testors or Krylon - didn’t say anything about acrylic clear coats though.
chutton01
I wouldn’t describe the Evan Design decals as whisper thin either although the lighter fluid tends to flatten out the decal edges far better than Solvaset does. However, the final flat clear coat over the model tends to help the decal edges disappear. If your decal design can use a clear background, you could certainly trim the decal edges right up to the image. However, I find this paper most useful for printing white lettering on colored background decals for adding (or changing) road names and numbers on rolling stock. This type of decal requires some area of background color around and between the white lettering to make it work, especially when applied over an old road name or number. At worst, the decal looks like a patch-out repaint but I have found that trimming the backround decal borders to match panel seams and/or rivet lines allows you to truly make the decal edges disappear.
The written instructions that came in the new package of Evan Designs decal paper have apparently been updated from those included in the package I purchased several years ago. The old instructions did not include the tip about using canola oil to turn the decal background clear. Instead, it mentioned that solvent based clear coats would turn the background clear permanently and that acrylic clear coats would maintain the white background. However, I must warn that I accidentally turned a group of white background decals clear when I used a spray can acrylic matte clear as the top coat. All I can figure is that something in the spray can propellant turned the decals clear. Prior to those decals, I had always airbrushed or brush painted Model Master Acrylic Flat Clear over the decals and they stayed white. An application of a solvent based clear such as DullCote over decals you want to dry clear will turn the white background clear permanently (I did this for the nose numbers on the fronts of a pair of Southern Pacific F7 locos in black widow pa
Does the dullcoat paint stick to the canola oil?
South Penn
South Penn
I don’t know whether DullCote will stick to canola oil as I’ve not yet tried the canola oil technique.
I tried the Evan Design decal Paper. Works as advertised. The only problem I had was the lighter fluid attacking the paint. I used Zippo lighter fluid and the paint was Krylon Ultra Flat white primer.
South Penn
I just tried the Evans Design paper and it had some issues for me. First, I had to set my HP inkjet to normal matte paper or it would put too much ink out that the images were blurred and bled all over.
I like that you don’t need to overspray to protect the ink.
I don’t like the thickness of the decal as I haven’t been able to completely hide the edges. It also didn’t conform to the brick on the building like the Testor’s did. I used Solvaset for setting my decals.
I will go back to the Testors paper as it worked better for me and didn’t show the edges once sealed.
Just my experience.
  • Bob
I bought a Canon Pixma printer a few years ago to replace my aging HP 722C, which was getting hard to find ink for. I like the Canon printer a lot better. For one thing, I don’t get any bleeding like I always did with the HP. I’ve also had trouble finding any inkjet decal paper, so I bought a package from DecalPaper.com and it’s worked very well, too.
I use Microset and Microsol to apply my decals, and Krylon clear satin finish to seal them to the model. It’s a good idea to have a gloss or at least satin finish on the model before you apply the decal.
