There was someone featured in an MR article who used horn hooks and the writer sweared he had one of the best horn hook operating couplers ever. The industry now has pretty much switched to kadee clones, but no matter what you are best to convert to kadees in the long run. Its been noted that many of the kadee clones dont stand up to the heavy use such as 100 car freights and break easily. The manufacture kadee clone is great for testing and couples immediatly to your stuff with kadees. Horn Hooks could not do that and you had to convert over.
The only coupler I know that couples horn hooks and kadees is the EZMate. While you are in the process of converting have a few conversion cars so you can run all your equipment still. I did the same thing.
If the issue is expense, you could look at KD-sized dummy couplers like Accurail makes, they’re cheap and will work with KD’s. They will even couple with Kadees on straight track. I use them on my ore cars, two ore cars in a set of five have a dummy on one side and a Kadee on the other. The cars in the middle only have dummys. Except for not having the uncoupling “tail” they look at a glance much like Kadee couplers.
Otherwise, if you have talgo truck mounted couplers on some of the cars, Kadee does make talgo truck/coupler combinations that you could look into on their website. [:)]
For me its no contest,knuckles only for me I change from UK 4mm scale which was all wrong anyway to US/Canadian modelling in 1979 and compared to American models then UK was all tripe and Geeps and Fs became my rostered locomotives and my first vcisit to Canada last year started off an interest in Canadian railways and have locos in GO Transit,VIA Rail,and CN plus the RDC all fitted with knuckles and all well detailed but next on my wish list are Rapido coaches for my Trainline VIA Rail F40 and GO Transit Bombardier cars for my GO F40 also Trainline.
For an initial cure to get you a conversion car (or indeed all if you wish), cut off the gathering tab on the horn hook with a good set of flush cutters, then cut off the protrusion underneath, you will be left with a basic knuckle, file the cut edges a bit to make smooth surfaces, and you will have a coupler that will mate automatically with Kadees (and most other magnetics), at no cost.
A cheap way to get you up and running, it can be a bit daunting to try and change everything over at once, this is a temporary cure that we find becomes quite permanent on older stock where switching is not required. Or just to get up and running again.
My guess at the price is about $2 for the couplers, plus you have to buy the 2-56 tap and screws, cut the old box off and glue it in place. Then tap out the plastic and mount the coupler. If you then have to adust the height, it is even more work. To me this is more work and money than I want to spend on when I can get a better car at a train show with the couplers already mounted for $4–and get my $4 back from selling the old car on eBay.
That’s strange. I did all mine with a $20 bulk pack of #5’s and some 3 cent screws from my hardware store. Got about 100 draft gear boxes from McHenry for $2. Total of about $1.25/car.
Guess I should have just got rid of them though…[banghead]
I’ll bite… but I’m not sure how many opinions we really need…
Most engines and some cars I’ve bought recently do actually come with horn-hook couplers that you can put on if you need them, which is not a bad solution.
If you’re interested, or become interested as you go along, pick a favorite engine and a couple cars and convert them to knuckles. As mentioned, the best of the best is Kadee, but others will work - especially on short trains without grades. Uncoupling with a pick (wooden skewer found in grocery stores) works best with like-brand couplers, i.e. all kadees. If you need specific help with a car, take some photos or describe them for us and we can offer suggestions. After you switch a couple cars over, you will either decide to to the rest, or retire your fleet and purchase more “mature” cars. Personally, I converted a couple of my oldest cars, and I use them regularly. I also have a fleet of tyco cars which, after temporarily converting a couple, I opted to pack away. There are lots of nice but relatively inexpensive cars available these days.
By the way, each conversion will be a little unique. The cars I converted had truck mounted couplers. I replaced the trucks with new ones that came with metal wheels and had no coupler mounts (actually, I bought trucks with coupler mounts but later cut them off). Then I mounted Kadee #5’s in boxes to the body of the car. Changing the trucks required gluing a new stem of styrene tubing into the car and using screws to hold the trucks. Then, there was a bit of floundering around inserting washers between the trucks and cars to raise the couplers to the correct height. Kadee makes a coupler height gauge which is very helpful once you switch to knuckles. It was pretty involved, and it took me a few tries to get to the final result.
You have not been gone long enough for the couplers to match.
No, they are not compatible in any way and that is really the good news. Once you have converted to regular knuckle couplers, the operation is improved to the point you can enjoy the hobby. The horn hook can be used if you convert one car with knuckle on one end and a horn hook at the other, you could still pull a train, but it will not back without problems.
I never had trouble with the dreaded ‘‘horn hooks’’ either, or worried about ‘‘coupler height’’, but I gave into the mass hysteria that I HAD to change to knuckles if my railroad were to be viewed by anyone, so I did, and the never ending disconnections, foul ups and general uselessness of those knuckles made me change right back to horn hooks! and… before theres a flurry of posts about what I did wrong, I used a height gauge, I used Kadee pockets, I used Mchenry AND Kadee couplers, I body mounted and I checked everything twice…and it was still a huge pain, those knuckles disconnect at the slightest pressure, hook say, 12, heavy cars up together , start pulling and pop! they come uncoupled. I got tired of it, I wasted time and money fooling with changing everything over, and you know what? not a SINGLE person ever even noticed there were ‘‘prototypical’’ knuckle couplers on my equipment, they did notice the constant uncoupling though.
So now I change those knuckles over to horn hooks, I don’t care if they aren’t prototypical, or they’re out of scale, or ‘‘old fashioned’’…THEY WORK!
So change them if you must, but be ready for never ending maintenence and problems.
