If you can find a suitable blue, thin it rather severely (80-90% thinner), then spray it on the inside face of the window “glass” while it’s still on the sprue. Naturally, test it first on a spare piece or something similar to adjust the amount of thinner and the density of the spray.
I do think, though, that the tint isn’t so much blue as it is a reflection of the sky. The reflection of the building across the street doesn’t look bluish.
(I really wish MR would correct the problem with some links not being clickable. To go to the link, highlight it, right click on it, and then select ‘Open Link’ or words to that effect). See Mark R’s solution to the problem below.
I have used their Clear Red and Clear Yellow (by brush only) and they work quite well for things like tail lights. I think that you will have to do some thinning if you want to use an airbrush.
Ya the windows have a mirror type surface and I agree looks blue because of the sky.
Nontheless, I still want to replicate that look.
I’ll go pick up that Tamiya clear blue acrylic paint and try that out using my airbrush. It says they reccomend the tamiya acrylic thinners? I supposed I cant just use alcholol to thin it?
I have used similar clear wrap for wrapping gift baskets many times. It is quite a bit stiffer than Ceran wrap. If you can get it to sit flat against the backs of the windows it might work quite well. However, I’m not sure that it will give you the desired tint if it isn’t attached to the back of the windows. For the price its worth a try.
On the other hand, I don’t think it would take a lot of paint to cover the insides of the windows. I’d be suprised if you needed a whole 23ml bottle. Keep in mind that you are going to have to thin the paint to spray it. You might not need more than a coat or two. Its not like you are painting an opaque colour where you have to put on enough paint to hide what’s underneath. I think the biggest advantage of using the clear coloured paint is that it will be deposited directly onto the window glass. There won’t be any gaps which could occur with the wrap. Think of poorly applied automotive window tint.
Anyhow, I’m speculating here. Please keep us posted on how you do the tint. I like the effect and I have a big hotel planned for my layout so I am curious to see how things turn out.
As a side note…I use a lot of Tamiya paint and have found that Denatured Alcohol works great for a thinner. For cleaning any brushes/air brush, I always use Lacquer thinner.
Ever think of taking a picture of a building with the sky behind it? Print on glossy photo paper after resizing to proper scale, then glue in from behind.
I’ve been considering something like this for a few of my structures.
Lowe’s has a material, in the window cover section, that could be a very thin mylar. Sold in rolls and having several reflective tints. This stuff is used to create thermal protection on home windows. It applies with a spray on liquid and spread with a squeegee. Altogether I think the cost would be around $35 for enough stuff to do an entire HO city scene.
I plan on trying it when I get to creating my urban scene.
The suggestion of taking a photo of a real building sounds like a great idea. Has anyone ever seen it tried before? It seems like it could be a little tricky until you got everything figured out, but it also seems to have a lot of potential.
I picked up a roll of blue cellophane today at the party city store. It was only $4 bucks.
I inserted a couple of windows, and taped the cellophane peice to the back of the windows. I think it looks great. And it will be easy to install on all the windows.
Once I paint the interior walls black and the roof, etc. The blue will appear a little bit darker, just like in that photo.
Something to consider … in the opening picture, you are looking UP at the building, in which that angle is reflecting the blue sky. On the layout, you are more looking AT or down on the structure … it wouldn’t be reflecting blue sky in the windows … unless you just plain want blue windows ! [swg]
