Occasionally, and it is getting more and more rare, you might see a 20 foot container that has two channels constructed in the bottom of the long side of the container that will permit it to be picked up by a fork lift that was designed for the purpose. These are being phased out of operation.
I believe that the side channels in the 20-foot containers were used primarily for lifting empty containers. Balance could be a real issue in using a jumbo forklift to lift a loaded 20-foot container.
They have to lift them in some way that ensures that the chassis comes up with the container. I was able often to watch them putting containrs onto chassis, and no IBCs are used. The containers are matched to horizontal pegs at the forward end, then dropped down to vertical pegs at the hind end. I believe chassis have locations near both ends in which the go out to the width of the container, and it has to be there that the entire assembly is lifted from above.
All container chassis have. Twist locks hold the container to the chassis . Side loaders and my jack cranes have arms that drop down and grab the bottom of the chassis and can pick up both quite easily
Thanks for that clarification, Carknocker! I guess I never saw them doing the twist. But your mention of the drop-down arms is definitely what I was attempting to describe.
I saw a several of those today that had “Empty Lift Only” (if I remember correctly) above the channels. Also, most had 4 channels. Several had the channels but I did not see anything about using them only when the container is empty.
That is a wee bit confusing… if they are “empty lift only” then they must fill them after they are on the train car and empty them before taking the container off the train car. Isn’t that just a boxcar?
I was just showing an example of how an ‘overhead’ spreader could have drop-down components to engage the bottom of a container or trailer. It is surprisingly difficult to find a picture of the Mi-Jack version even though Walthers made a model of one.
I always thought the two ‘forklift grooves’ in the bottom were for the container handlers that are used to move and stack the empty containers.
