Hello All:
I am in the process of fixing my childhood 202. The paint is very rough and I was wanting to strip it down and do a repaint. What products can I use and not damage the plastic shell? Also, what is the best paint to use to get a color match? I saw online that the decals are available. Thanks for any help sharing your knowledge and experiences.
Mickey D
Hi Mickey!
Youâve got the Lionel Union Pacific Alco FA 202? OK, probably the best way to get the old paint off is immersing the shell in Simple Green concentrate. It may take a week or two to loosen the old paint but the stuff does work and wonât hurt the plastic.
Iâve also used 99% concentrate isopropyl alcohol but sometimes it works and sometimes it doesnât. Itâs expensive too, Simple Greenâs a lot cheaper.
As far as matching the original orange paint thereâs vintage Lionel color paints available from Henningâs Trains. https://henningstrains.com Look under âCollector Color.â
However they sell it in half-pint cans which may be more than you need. I like Tamiya paints my self but if thereâs no hobby shop in your area you can try Rustoleum all-material paints. In both cases youâll have to go for a close enough. If anyoneâs aware of Post-War Lionel spec paints theyâll have to sound off.
As far as I was aware, the âCollector Colorâ paints were really for matching pre-war Lionel colors, not so much matching postwar Lionel items. I donât think the orange would be a good match.
Regarding paint stripping, Iâve used Easy-Off oven cleaner to strip paint with reasonably good results, no harm done to the plastic.
A word of warning, the 202 had heat stamped lettering- this generally leaves a slight physical impression in the plastic, that will remain after paint has been removed. You may need to spend some time with filler and sandpaper to âsmooth outâ the impressions in the shell, so you donât have the âghostâ of the old lettering lingering on in your re-paint.
-El
Very satisfied with EZ-Lift-Off. Donât know if it is still available, but it does no harm to plastics.
Thank you for all of the input!
Youâre welcome! And best of luck with the project!
