I looked into G scale. I have the yard space so that was not an issue. The track was kinda expensive which set me off. What stopped me from pursuing it further was when I heard from other g scalers that you spend more time gardening than on the railroad. I do NOT like gardening at all.
I hear you. I don’t have much of a green thumb either. I built a small G scale layout about twenty years ago out in my shop but quickly grew bored with it and tore it down. I still have the loco and most of the freight cars. It all came from a set that someone bought for me at Walmart around Christmas time. The thing that gave me a renewed interest in the scale was a 2-8-8-2 that I saw at one of the train shops in Houston a while back but it was priced at around $1,000.00 which is out of the question right now. There are much cheaper G scale locos out there…
You’ll get more and better responses on the Garden Railways forum. I’ll move your post there so more people with garden railroad experience will see it.
I went with G in our garden in 2004, it was a blast! Lots of fun at first. The thing I didn’t count on was varmints.
Here in Bakersfield we have dozens of little creatures that took the fun out of our garden railroad.
Ants, they use the rails as freeways. If crushed and left on the rails their internal acids will eat the brass rails. That means running a track cleaning car in every consist.
Just like an indoor model railway a garden railroad should be planned around what you think you can accomplish and maintain. I always had an indoor HO layout and often thought about building a garden railway but it wasn’t until I retired that I had the desire to do something with my leisure time. I started out small with a cheap Bachmann Big Hauler set and a loop of brass track around my patio. No digging or anything like that. The bug bit hard and I was soon planning a more ambitious layout that ran around the entire backyard. I like gardening so that helped. I did the research into the do’s and dont’s and must say I am happy with what I have accomplished. I would follow many of the same rules that apply to indoor layouts.
Good benchwork (in this case what you support your track with in the garden) and good trackwork are essential. My railway is ground level. Some will advocate for raised track on some sort of wood or stone base. That’s easier on the back. Just take care to do either one with the proper materials and techniques. Climate in your area will have an impact.
Cleaning track must be done more frequently when outdoors. There are motorized track cleaners available but they can be pricey.
While proper electrical feeders are essential on any model railroad, they can be critical outdoors where the elements take a toll on track joiners and such.
Before we can give any specific advice to your questions we are going to know a bunch more about where you live. What is your micro-climate like? Are you subject to ground freeze-thaw upheaval? What type soil do you have? Clay? Sand? Loam? How much rain? Do you have large puddling after rain storms? How level is the area where you plan on building your empire? These answers will help us give better hints for your construction.
Routine maintenance like weed control and plant trimming are much the same as you already do for your lawn. Do you plan on ground level or will you build an elevated area for the trains? An elevated empire has the advantage of better drainage and a place to sit while building and maintaining your empire.
Do you plan on using sectional track or longer ‘flex track’? Unlike the indoor smaller scales where you glue cork to plywood and then add a few screws to hold the track in place, outdoors you will be building a subroadbed from crushed stone just like the real thing. Your track will ‘float’ atop this roadbed allowing it to contract or expand with the weather. The standard slip joints that work fine for years indoors will not fair so well outdoors. Over time they will fill with dust and debris and you will lose conductivity. Slip joints will over time slide apart giving your trains the opportunity to ‘pick a joint’ and derail. Rail clamps solve this problem very well, I have some in place th
Track cleaning cars need not be so expensive. Cut a piece of wood to fit under a box or passenegr car. Drive a couple of long nails through the wood, and some small finish nails at each end. Stretch a green scouring pad across the small nails. Drill a couple holes in the bottom of the car and let the ‘cleaning unit’ float under the car. After a couple laps stop the train and let the cleaning block drop away and put the car back into normal service.
You don’t have to play in the dirt on hands and knees to have an outdoor railroad. Consider a raised table top layout, it eliminated almost all the negetives listed above plus a few others. As far as track cleaning and rail connections there is always on board battery and RC control.
Check in at “Large Scale Central”, look and ask, you will get plenty of answers from all corners of the large scale hobby.
Below is a link (you tube) to my last railroad 2005-2014 it was torn down because of a relocation, I am now building a new one using the same, but improved, methods.
I want to echo Tom, “Now go get a starter set and a few additional sections and start playing in the dirt.” You can really get a sense of what you want to do by just letting a train loop around the proposed area. That is what I (we) did over a couple Christmases before I got CINCHOUSE permission to break ground. By that point, I had a rough vision of where I wanted to go, what I could spend, and how fast I wanted to get something up and running. Were I to do it over again, I would’ve kept the trains out and tinkered with simple loops for a few months rahter than boxing them up on the first day of Epiphany!
I would also splurge and buy a couple books on the subject. There is great advice on the forums, and, unlike some hobbies in which I participate, to date it has all been constructive. I just work better off of books. They also have a nice sampling of possible “strategic direction,” to include plantless.
For what it is worth, I have a near-black thumb that a few design flaws made worse. I still managed to get some greenery going in my “raised bed gravel pit with train.” Stick to cheap plants until you find stuff that works. Through trial and error, we now have a few areas that, dare I say it, look good!
I also cannot echo Tom’s points on tracks loudly enough. Ours is a small layout, so I bought bunch of clamps, and I just install them as joints simply get too nasty. It spreads out the cost over time. And as for track cleaning, on our little road, a greenie weenie on a “swiffer broom” works wonders. I can usually ge the Triple O u
One thing I haven’t seen mentioned. What’s the purpose of the railroad? In my case, it’s an excuse to sit on the patio with my wife late in the afternoon and have an adult beverage or two whilst watching the train slowly patrol the back yard.
In fact, the whole idea was hers. We were walking through Hobby Lobby one day and found a G scale train set on a clearance rack. Took it home and set it up in the living room. Decided to take it to the back yard. Wife says “we need to do something more with this.”
Fast forward past the expanded patio, privacy hedge, lawn shed, assorted flora, and a years worth of patience while the plants grew (or didn’t) and track was laid. As far as maintenance, I put a red 3M scratchy pad on an old Swiffer handle and psuh it around the track (about 140 ft) before each operating sesssion. Takes about 3-4 minutes. The only other maintenance is in the spring when I have to put down new pea gravel (for ballast) in some areas of the track. Also need to re-ballast sometimes after a heavy rain. I used to have to repair the track on the west end where the deer would walk on the track. Since I built the bridge last summer I haven’t had that problem.
My first few garden lines were ground level, track powered with mostly LGB equipment. But as I get into my mid 40’s, I decided now that ground level will only get more difficult to maintain, and add to that, the new family Beagle liked to dig up stuff and leave his calling card on the rails. So up it all came. Right before that happened, I converted everything over to onboard battery power to better get along with my live steamer. We have a small raised line that is built like a planter box with some live plants but that is about to change as I have gotten into gauge one trains on the same track, but they need broad radius curves. So a new raised line will get built this summer with 8’ radius curves(16’ dia circle) to suit gauge one live steam. I plant to recess several planter boxes into the benchwork to have live plants, and the track will be ballested. So while it will be a raised set up, it will maintain the look and feel of a garden railway. One area will have a shelter built over it to give a shady spot to raise steam and seek shelter from a shower when we host steamups in the future. Mike the Aspie
Our roster includes 2 LGB engines with onboard battery power, an old 2080d and 2073d, an equily old Kalamazoo 4-4-0, 2nd generation Bachmann bug mauler(Big Hauler) an old Hyde Out Mountain live steam Shay(my wife’s engine) and my pride and joy, an Aster Southern RR(UK) Schools class 4-4-0 live steamer. Mike the Aspie
