How to disassemble Athearn SD60
Hi all!
I have bought a mentioned engine on e-bay, but it came without windows. Now I need you guys to help me out how to disassemble the engine. Another thing is, where to get the extra set of cab windows?
Please, keep it in simple English, I’m from Croatia and sometimes I really don’t understand what the forum crowd is talking about.
Thanks in advance.
Remove coupler pockets.
Look for extra screws around the bottom of the frame (not the underside of the fuel tank).
Wiggle the shell off.
David B
Unscrew the coupler boxes. Also look under the trucks. There should be 1 screw under each of them.
Here a pic with arrows pointing to the mounting Studs
I took the pic when changing out the decoder.
Guys, thank you very much for the disassembling tips. You’ve helped.
Anything on the windows?
Bye.
Dan.
The SD60 window set is Athearn part number 80515.
