I got a little bit of the stuff on one of the roofs and would like to clean or dissolve it and repaint the affected area.
What is the best method for this?
Well you don’t say waht the material is but if it is fairly new it acts a lot like rubber cement. a little judicious back and forth rubbing with your finger may just take it off. Another method that works if a bigger amount is to stick a very sharp toothpick into the blob and then roll it. The Goo will wind around it until it is removed. I would go the solvent route as a last resort. Goo gone will remove just about anything but I would be careful on plastic.
It is alot like rubber cement.
I managed to get most of it, the roof will recieve a bit of weathering anyhow and hopefully conceal some of the paint damage from the attempts at removal.
I managed to save the roof sections where they meet but took some pretty drastic measures. Snipping off a plastic sprue and cementing it under the center line did the trick. They dont tell you about these in the instructions.
I was using Goo on small chopped wood blocks under the two roof sections as a sort of a brace system. Unfortunately a little bit got on the finger which was transferred elsewhere on the building. Presto… glue spot. Grrr. lol.
It is a mix of rubber cement and a solvent based cement so it could mar a plastic surface. the rubbing method mentioned above has worked well for me, so has gently working it with a sharp knife to “herd” the cement into a ball that can be pried off. It also softens with heat I have discovered – not soldering iron heat maybe but perhaps a hair dryer type heat.
Dave Nelson
