I am getting ready to assemble a New River Mining Co. kit from Walthers. It has about 30 windows molded in clear plastic. How can I paint the window frames without getting paint on the windows? Any help will greatly be appreciated, as I need to get it built, I have 18 Tichey ore cars assembled, and no way to fill them.
Thanks for any help you can give me.
Bob Langford sego65lilly@msn.com
Bob: Sorry, I’m not familiar with this kit. Are you saying that the window frames are not molded on the wall part of the kit, but are on the clear window material? How you are going to paint them depends a lot on where they actually are. If they really are molded on the clear material, they must be raised a bit from the window panes. I think in that case your best approach will be to get a liquid masking material and carefully paint over the panes with the mask (Micro Mask is a brand that is swimming slowly from memory) When that’s dry, paint the frames with a fine brush. Then remove the masking material according to the manufacturer’s instructions.
I’ve not run across any kit that has the frames molded onto the clear window material, but there’s always a first time!
Something I tried and it worked pretty good. Assuming black frames, get an inexpensive stamp pad. Wrap a piece of double sided tape around your finger, stick one of the windows on the tape and lightly touch it to the stamp pad. Since the frame is raised (assuming you’re doing the correct side) only the frame gets the color. Worked real well for me.
Hmm… If not black frames, you could probably dampen a piece of felt with the desired color of paint and do the same thing. Good idea!
I used a black fineline Sharpie to paint my New River Mine window frames. Worked great. I also cut out about 1/3 of the windows and added them to the kit as open windows. It makes a huge difference in the appearance of the kit.
Robert ; If you can’t remove the windows, your going to lose a lot of time and patience.
Removing them now , then painting , and then replacing them , even if you have to buy new sheets of clear acetate is your easiest / fastest ,solution.
I always paint myy frames the old fashioned way, with a 000 brush. It is tedious and time consuming, but I have yet to find another process that looks as good.
Ron
I’ve found an easier solution than a paint brush for detail parts. I don’t have a steady hand, so a paint brush was out of the question, because I [ush down slightly on it, splitting the form of the brush and getting paint where I don’t want it. I use flat toothpicks carved to a point on one end, and loaded wiht a dot of paint. Works for me, and it’s much easier and cheaper than a brush(i.e. 500 toothpicks for the same price as a 000 brush)
Noah
I just made this model last month. The windows are clear plastic with moulded on frames. I used the black sharpie method. A medium tip with a careful hand and you can just color the raised frames. If I got unsteady and got some back on the surface of the window, I just colored the whole pane back as if it were a window that had been broken and filled with a black board. Once the windows are done, you can install them after the rest of the structure is painted.
Hey guys, the sharpie method and the pad printing method will be on my list of things to try in the future. Thanks!
