Recently I’ve been working on chain link fence, and perfecting my technique, which I’ve developed using several different sources. Hopefully this helps those who want this type of fence on their layouts, and let me know if you have any questions.
0.32″ music wire- I got mine from Hobby Lobby, made by K&S Precision Metals.
1/16″ metal tubing- This is only if you plan on making opening gates. I got mine from Hobby Lobby, but I’m unable to locate it on their website, so here it is on Amazon.
Since I have a few scenes on my layout where an industry requires fencing around its entire (or most of its) perimeter, I prefer to use the Walthers chain link fence kit for the vertical fence poles (with extensions for barbed wire). However, as the total fence length can be four or five feet long. I substitute 3’ lengths of .020" piano wire for the “florist’s wire” horizontal “tubes” supplied in the kit. I start by drilling .020" holes through the molded-on top and bottom sleeves of the Walthers fence poles. I do this while the poles are still attached to the parts sprue to make it easier to hold the poles still while drilling. Once all the poles are drilled, I mark the lengths of piano wire with marks every ten scale feet. I then thread the poles onto the two lengths of piano wires and glue them in place using CA. Make sure to work on a large flat surface to help keep your fence straight and square.
The most difficult and time consuming part of making good looking chain link fencing is accurately cutting the tule material. I start by first misting the tool with black spray paint as it makes it easier to see on my cutting mat. Using a brand new blade in my hobby knife, I then true up one edge of the tule to make sure it is straight along one row of diamonds. I don’t use a straight edge as I find the tule fabric tends to shift and twist while cutting, even with a fresh blade. Yes, I cut each individual diamond to ensure the final fencing material is indeed straight like the prototype. I next count down the required number of rows needed to slightly overlap the two lengths of piano wire and cut along that row of diamonds. Take your time and be patient so you don’t find yourself cutting along the wrong row half-way through the job. Use magnification if you need it (I do!).
When ready to glue the tule to the fencing frame, I like to use PSA glue from MicroMark.
I use 0.020" phosphor bronze wire for my fences. It is stiffer then brass wire but still easy to solder. I also use teulle for the chain link. For the barbed wire I use 32 gauge magnet wire soldered to the uprights.
All of the horizontal parts are one piece and then they are soldered to the vertical posts. I make the post about 2 scale feet longer on the bottom to give me something to plant in the ground.
I use CA spread with a sewing pin to and then set teulle in place. I trim off the excess after everything is dry. much easier (for me that is) than trying to cut it then line it up.
After Its all assembled I airbrush it with old silver. I didn’t do any rust on this fence as I wanted to make it look like it was recently installed.
Thanks for the comments and tips everyone. I’m always looking for ways to perfect my technique. I agree that buying a kit from Walthers is easier, but in my case I won’t need as much, and I like to save money where I can.
Using poster tack to hold pieces in place for soldering.
Using a silver sharpie to paint small parts.
What do you know, you can teach an old-dog new tricks. I have never thought of either one of these.
Thanks for the great tutorial and for sharing your techniques. Also, congratulations on the successful soldering and fence construction. It looks good.
When shopping for tulle, look for reminants. I got sone pieces 6-8 inches wide, long enough for scale miles of fence for about $1, if I remember right.
When I built some chain-link fences about three yrs. ago. I used 1/16’’ posts with 1/32nd stringers that were 1’’ longer at the bottom edge, so they would fit into holes drilled into My Homasote top of layout, making the whole fence removeable, when need be. The layout is partial open grid, 1/2’’ ply over grid and 1/2’‘Homasote over ply. Tracks are all spiked down, ballast glue does the rest. There are also two working slide gates, modeled after some prototypes that I passed through for 15yr’s at a truck line I worked for. All parts are hardened brass from K&S. Mesh is 1/32’’ hole Copper that I had shopped out…so, it was not cheap, but to Me worth every penny. I have made over 600 scale ft. of it, in just one spot alone.
All photos may be clicked on for a larger view:
Below pic shows the part standing with one end has sleves soldered in place to accept the piece laying on the bottom, that the top/bottom stringer slides into. They are all made on a jig, 100 scale ft. in length:
All this was soldered with Solder-It Silver bearing solder paste…So much easier to solder with…one hand free, no need to hold to solder with iron. Paste also has built in flux.
Thanks for the info Richard and Frank! All this information will be helpful in the future if I ever want to make an updated tutorial. I like finding many methods for making something and combinding the best from each while adding my own techniques.
Great tutorial Harrison as I enjoyed it. You really did a great job on that fence. Impressive!
Judy is forever finding stuff and saving it for me like the styrofoam tubs that meat comes in. She recently found this really micro grid material that looks perfect for N-gage chain link fence. Unfortunately the fine mesh lace is bright red. I’m hoping to bleach it and try out your silver permanent marker trick to find out if that works. This material is so alter fine, I’m afraid spray paint might fill in the checkered voids.
I’ll let you know how that silver permanent marker trick turns out when I get to it.
