Hump Yards
Has anyone else built a hump yard on their layout? My hump yard is 19 feet long. It has 3 arrivla, 3 departure, a through train track and 10 classification tracks. The longest two are ten feel tlong. I also have all of the the other tracks associated with a hump yard (e.g. no hump track, caboose track, bypass track, rehump track, etc.(. The railroads main service facility is at one end and the car shops are at the other.
Ira
[8D]Sounds pretty neat! How about some pictures?
Ed
I’ve always wanted to build one. Just never had the space to do anything decent. I have wondered though…how would you make retarders functional in scale since model physics and dynamics are so radically different than that of the real thing?
Yes…please. Post some photos.
Mark H
I’ve only ever seen one hump yard model. Years ago at the Springfield show, there was an HO hump yard modular set up with the main layout actually humping cars during the show. The owner had built it to use a tethered DC throttle custom made with an extra button. This button controlled air jets that blew out of small nozzles pointed up the hill on all tracks.
He had an under the track Kadee magnet at the crest of the hump and slowly pushed the cars over the top. As each car uncoupled and rolled away, it would head down the bowl tracks only to be retarded by the use of the air jet by push button. The air was strong enough to blow the car back up the hill (I saw him do this).
I gather that the cars being humped were all his cars specially tuned to be humped, with free wheeling trucks and perfectly adjusted Kadees…otherwise it wouldn’t have worked.
I don’t know what the grade was, but it was pretty steep. I know it was tall enough for a train tunnel under the hump, so that’s at least 3" right there, plus another 1" or so for track, roadbed, etc. IIRC, the whole thing fit on three modular pieces with the hump in the middle.
Paul A. Cutler III
Mine is N scale. The top of the hump 1.375 inches high. I do not use retarders. All of my cars have MT trucks with Atlas metal wheels and are very free rolling. The bottom of the hum has a wye which splits the classification tracks into 5 east and 5 west classification trcks. When rollied over the hump cars will roll well into the bowl before stopping. It seems to work pretty well. The grade up the hump is 6 percent, I do not care what the grade is into the classification tracks since engines do not use it, but it is about the same as the inbound side of the hump.
Ira
Since this is somewhat hard to model I’m going to represent the departure tracks next to fueling stations and main lines and have the hump in the background. This could be easier to simulate with a working hump yard.
When I was a crane operator for CSX Intermodal, right next to our property, which was a 16 track double ended yard, was The Belt Railway, classification/hump yard, 5&1/2 miles long. One of the largest Hump yards in existance today. Works 24/7. Check out some of the Video’s and more. Rail fanning from Your PC:
http://www.youtube.com/watch?v=ndryMwF41Kk
Frank
Modeling a hump yard requires an enormous amout of space. I have seen the hump yard Paul3 mentions @ W. Springfield. A considerable amout of design, trial and error and specific rolling stock is needed for reliable operation. The air blast “retarders” are probable the best method of slowing cars. Others have tried all sorts of means to do this, actuacing series of wire or plastic bristles popping up to snag axles etc. Cars need to be free rolling and weighted properly, even then various designs may not work as well ie: flats, gons etc. Although it may seem like a great thing to model, even if you have the space to use, all the issues and devices to have work correcly just don’t seem worth the effort.
The late Ed Ravenscroft was a pioneer hump yard builder. I saw his second one, in Phoenix, about 35 years ago. It was totally automated, with the air jet retarders timed to rein in fast cars but be off before slow-rollers reached them. The hump switcher would move one car length after the retarders cut off, launching the next car in his 10 car hump cut.
Believe it or not, he used NMRA X2F couplers (the despised horn hooks) and they worked flawlessly. Of course he had accurately dimensioned items - he had been NMRA President when they were developed. I believe his hump yard was a driving force behind the NMRA’s car weight RP - heavy enough to roll, light enough to roll easily.
The down side was the electropneumatic monster under the benchwork. Seeing that pulled the pin on my own half-formed plan to build a hump yard. My rather small subdivision yard is flat-switched. (I’m considering adding air-jet anti-retarders to get the push-switched cars all the way into the body tracks.)
With ALL cars, including flats and gondolas wighted to th eNMRA standard and free rolling wheels th ecars wil lget down th ehum withou any problem. My cars roll through the wye and then four #5 switches and roll at least three feet down the classificaton tracks. the trick is weight and free rolling trucks. It atkes time to ensure that the cars meet the standards,but ultimatley it is worth it.
Ira
Hi guys
thought you might be interested in this
http://www.btmrs.co.uk/hazlebury-yard.html
There is a small push button panel on the front where children can push a button corresponding to a track to “control” the hump.
Trevor
http://roundtreessidings.wordpress.com/
What happens after you have a few cars in one body track? Doesn’t the next car down hit them with a lot of force? Some video of your hump yard in operation would be interesting. Getting one car to roll down a hump is not difficult. Being able to manage the different speeds needed as the tracks fill is where most folks building hump yards discover the need for retarders – or for ways to speed up the cars.
I only know of a couple of successful model hump yards – and none without retarders (compressed air jets in the cases I know of). Just like on the prototype, slamming cars together as the cut grows is suboptimal.
Ira, I also do N-Scale with Atlas metal wheel sets.
I have done some practice for a hump yard and also know that it would work in N-Scale. Since my layout is not of a major division, or even sub division I do not do a hump yard.
I haven’t built a hump yard for my layout, but I would think that some grass clumps glued between the rails, sticking up just far enough for the axles to drag on would work.
The string of cars run over hump push the standing cars down the trck. I have tested this using various combinations of cars.
Ira
It may be that some folks do not know how hump yards work in the real world. A “string of cars” does not roll down the hump together, typically only a single car at a time. That is the whole point, so that each car may be individually classified into a separate track.
Also, using toothbrush bristles or some other means to slow all cars equally does not help, as the first car into a track must roll faster to have enough momentum to travel well down the bowl track. The next car bound for that track must have a little less momentum, and so on as the track fills. Otherwise (as I noted before), the fourth or fifth car bound for that track will be rolling so fast that it will slam into the already-parked cars with a lot of force.
That’s why a realistic hump yard requires varying degrees of retarding of cars – and why they are so hard to build in the model.
I encourage the OP to post video of individual cars rolling down his hump and rolling into class tracks with varying numbers of cars already there so that others may see how it works without retarders.
i found video that prove you wrong about a sting of cars going down a hump go to 4:22 of this video.
https://www.youtube.com/watch?v=V0l4v9z5-oI
It works for me. I will b humping either the 5 weasbound or 5 west bound tracks a one time. The other one will be pulling cars to make up a train. Since each side of the classifcation tracks will hold 106 cars at one time and I not be humping that many before going to the other 5 tracks, I will have plenty of room to hump a train into the bowl. The longest train that I plan to have that is not a unit train is 25 cars…
Ira .
The preceding 4 minutes of the video prove me right. Yes, occasionally a block of cars go over the hump bound for the same destination. That exception proves the rule.
Apparently folks don’t care to understand how things really work and wish to call something that doesn’t work like a hump yard a “hump yard”. Asimov was right.
The orignal poster may call it whatever he likes. Doesn’t change what the yard does (and doesn’t do), but it’s his layout, of course. But one modeler’s opinion also does not change what “hump yard” means in the real world.
It’s amazing sometimes. It appears that some never even looked at the video’s that I posted in the beginning of this thread, with ‘‘hump yards’’ in operation.
You can lead a horse to water, but!!
Frank
