After many years of running HO scale DCC, and not once frying a decoder after getting it installed, I’ve switched to N scale. I have 5 DCC engines, and a few DC engines. I’m using a Kato power pack, until I can finish converting my remaining engines.
A ScaleTrains with an ESU decoder works fine. A TCS decoder in a Kato P42 works fine. A Digitrax decoder I installed in an ACS-64 works fine.
But I’ve managed to fry a BLI decoder 2x now, and just tonight a Digitrax sound decoder in another P42. The interesting thing about it is, they were both running fine, didn’t derail, and just quit working. The latest casualty was running solo along a 10 foot length of straight track when it just stopped dead.
I’m thinking I need to stop using the Kato Power pack ASAP, but I’m curious if anyone else has any other suggestions, before I fry another decoder. Is the Kato power pack known for frying decoders? Any and all sage advice is appreciated here.
Are you running in 14 volts, 20 volts, or other? 20 volts could be too much for dcc decoders. Also, make sure all of your decoders are DC/DCC. The hobby has leaned mostly toward decoders compatible for DC, but just check…
Most N scale locos use a split frame pickup system, and in many cases the motor wires wrap down over from the factory light board. Most board replacement N scale decoders either come with or tell you to put a small piece of Kapton tape between the motor tabs and the frame or decoder because otherwise it will short out and fry the decoder. Witht he small space, the installation is much more critical. It could be find but after it runs for a while, the bibration could cause a contact point to develop. It only takes a brief contact between a motor wire and the frame of the loco and the decoder is toast.
Yes, the kato power pack is DC. I’m using it because the layout is wired like a glorified oval at this point, over 1/2 of my engines are DC, but most importantly, when I was setting everything up the Kato one was right in front of me, and the Digitrax system was packed away [:P]
While it is possible to run your DCC engines on DC, it really isn’t recommended. DC voltage can be “dirty” and produce small voltage spikes. These voltage spikes can easily exceed the maximum rated voltage of the decoder. If the decoder receives enough of these spikes, it can destroy it.
Just because you can, doesn’t mean you should. [swg]
Some decoders need to be in dual-mode to be able to run on DC.
From what I understand not all decoders are set to default to dual-mode.
If not configured properly a DCC decoder could be damaged by running on DC.
Unfortunately once the decoder is fried there is no way to tell how the CV was configured.
I suggest, if you are going to continue running the other locomotives on DC, consult the decoder manufacturers website about dual-mode or running on DC.
The Digitrax website says that their decoders can run on both DC and DCC by default.
Other decoders might not fair so well on DC power.
As the op has found out, while you CAN run DCC and DC “together”, it is typically only a matter of time before something burns out. Pick one or the other operating system, and run only those locos set up for it.
