I finally got all the tools I need, the wire, the solder, etc. to create 0402 “incandescent” fixtures over the doors of Rocky Mountain Drilling. Thanks very much for those who recommended Ngineering - they ertainly have everything I needed - almost.
Forming their .018 tubing into a gooseneck lamp conduit and attaching a shade was pathetically easy. The first one came out looking fine (I’ll post pictures when I get the rest of it to work out).
Soldering #38 magnet wire to those 0402 LEDs is anything but easy. The first one was a dismal failure. I got one wire attached, but it came off and the LED disappeared when I started working on the second wire.
I can’t get the first wire to even attach to the second LED. I tried several times. these things are so darned TINY! Even with my 5X Optivisor AND a magnifying glass I can’t see well enough to do the job. I’m thinking I need one of those very large magnifiers with the light around it to do the job - with about 20X magnification for these old eyes.
In any case, it’s going to take several attempts to get the hang of attaching these wires. I may pull out what little hair I have left before I get there.
Anybody know where I can get pre-wired LEDs with #38 wire? What I find on EBAY doesn’t specify wire diameter, and from what I’ve seen the aire is much thicker, meaning it won’g go through the .018 dia. tubing.
What I’ve found handy is holding the SMD LED steady when soldering wire to them and I use a good set of locking tweezers to do that:
Tin the contacts of the LEDs and stripped wire first THEN solder them to one another. (A wee smidgen of rosin flux paste helps, too.) With this method I generally don’t have any problem soldering 34 AWG magnet wire to 0402 or 0603s.
34 AWG magnet wire has an OD of 0.007" so you should have no problem getting that through the 0.018" tubing. And it’s coated so the insulation is extremely thin. To strip the insulation just heat a blob of solder on the tip of a 700oF soldering iron and move the magnet wire in and out of the molten solder. The heat will both strip and tin the wire all at the same time. You can pick up 20’ of 34 AWG magnet wire from Litchfield Station for $2.
I went to Hobby Lobby and bought a cheapie ($20) Ottlight. You can see the base of it in the photo below. It has 2X magnification, plus a small 5X spot magnifier. Combined with my 2.5X Optivisor, I can almost see what I’m doing. I might try to buy the 3.5X Optivisor lenses and see if that helps. But the Ottlight did help - a lot.
But also in the photo below, you can see that I was successful! I soldered leads I could barely see onto pads I could almost see, and miracle of miracles, it works! I am encouraged!
The thing is probbly more fragile than a robin’s egg, and I doubt it’ll survive being threaded into the gooseneck, but getting only the second LED I messed with (the first is mimicking a grain of dust on the floor somewhere) to light is a major victory. Now I just need to figure out what resistor will provide the right amount of light. I’m using a decade box for that.
Excellent! - Glad to hear you’re making progress, Mark. [Y][8D]
FWIW, in regards to resistors and SMD LEDs: I ended up using MUCH larger values for the 0603 LEDs that I installed in my brass locomotive headlamps than I expected. 10K, in fact. I think because the SMD LEDs are SO tiny that the concentration of the light makes them look brighter than a 3mm LED.
Here’s what a 0603 LED looks like with a 10K resistor:
It’s plenty bright but not overpowering. With only a 1K resistor?..it was absolutely blinding.
For lighting with lampshades, it may take some experimenting to see what resistance works best. And, maybe…you have different intensities in different locations for different lighting needs - e.g. indoor lighting vs outdoor lighting. You’ll best be able to determine that through experimentaton. And switching out resistors is a lot easier than switching out lights.
Oh, and I just remembered: Double-stick tape is another handy method of holding those tiny SMD LEDs in place while soldering to them. After your done just pry them up carefully with a pair of small tweezers.
I just ordered a bunch of 0603 LEDs. The 0402 is about the scale size of a 60 watt bulb, which is probably too small for most of my needs. The 0603 is roughly the size of the old large base incadescents that were used for a lot of exterior commercial lighting.
I miscalculated on the scale sizes before - I thought the 0402 was about 6 scale inches long, but it’s only about 3 1/2" long. Dummy me. But I’ll be able to use the 0402s elsewhere, I’m sure.
What sort of magnification setup do you use to be able to solder those tiny components? Are you an eagle-eyed phenom, or…? [:D]
How many power magnification do you use to be able to see everything? If you could be as specific as possible, I’d sure like to know what you use. Even with a 2X magnifying lamp and 2.5X Optivisor on top of that, I still can’t see the LED solder pads clearly.
Although I wear trifocals, my sight is still pretty decent @ 62. I just use a Mascot 2.5x “optivisor” (leather headband) over atop of my glasses with a good task light. The task light helps to reflect the shiny soldering pad.
I used to have 20/15 vision until my early 40s. Miss those days. [sigh]
As mentioned, I like to use a smidgen of rosin flux paste on the soldering pad of the SMD LED. And once I’ve attached the wires to the LED, I clean up any flux residue with 99% isopropyl alcohol and a cotton swab. If the solder joint is nice & shiny, it should hold well mechanically, as well electrically.
The above are wires soldered to two 1206s that have been glued & soldered together in parallel. This was used to illuminte the open firebox of my brass 2-6-6-2 Mallet to replicate firebox flicker.
I was quite surprised at how robust those little wires are. I have broken a couple when I caught a finger on them, but it was quite a tug that broke them.
I use this Array Wizard to help get started on choosing a resistor.
You’ve got better eyes than me, Tom! And I’ll bet you have pretty steady hands, too (mine are also pretty steady, so at least that isn’t an issue).
I just picked up a 2.25X magnifying lamp, and it helps a lot. The lens is surrounded by LEDs that can be adjusted in intensity for just the right light level (full bright looks good to me). I have a 2.5X Optivisor, and between the two I’ll get 5.625X magnification. I also ordered a 3.5X Optivisor lens, which will give me 7.875X combined with the lamp. I think that will do.
Brent,
That Array Wizard looks pretty useful - thanks! I’ve bookmarked it.
I’ve been a technician for over 30 years and used to working under a microscope so - yes, I have pretty steady hands, although not quite as steady as they used to be. Like anything getting older, you learn to adapt to your limitations.
The extra magnification will definitely help, along with the strong task light. I picked up one of thos 2x LED magnification lamps at a train show a few years back. I don’t use the magnification window much at all but the lighting is great for illuminating the area that I’m working on.
I made a three clip tool to hold a 402 LED in the center and the red and green wires on the outside.
This tool really makes it easy to solder the itty-bitty LEDs. I use #46 Litz wire. For me it was harder to hold the wires in place than hold the LEDs. The two outside clips holding the wires work great even for Shaky Hands Mel.
Mel
Most of the SMD LEDs I buy are pre-wired but there are times when I want something modified and use the flattened, thoothless alligator clips for holding the parts.
First, I hope the wires are fine enough to suit your needs.
Second, I don’t think you are being lazy at all! I became quite proficient at soldering leads to 0603 and 0402 LEDs, but I had to ask why I was going to all that effort when somebody else was willing and able to do it for me for a very reasonable price. I decided that I’d rather reduce my neck and eye strain and spend my time on something else.
I’ve purchased SMD LEDs with wires already soldered on. Some were soldered fine; some I didn’t like the quality of the soldering (crooked wire(s), cold solder joint, etc) so I re-did myself. I guess that’s the curse of being an electronics tech for 4 years.
If pre-wired LEDs help you accomplish what you want and need to do and you save time doing it, there’s nothing wrong in that in my book.
I can give you an example of where buying prewired LEDs was well worth the price.
I bought eight Showcase Miniatures dwarf signals #2194. They offered prewired tri-colour LEDs to go with the kits, but they wanted $10.00 USD each, which I initially dismissed as being an outrageous price so I didn’t buy them. I had some prewired 0605 (?) LEDs already on hand so I thought I would just use those. However, it soon became apparent that fitting my LEDs to the very narrow styrene signal bodies would require some kit bashing, and even with that, it didn’t look like all the colours would shine properly through the lens.
Rather than butcher things, I decided to order the recommended LEDs from Showcase Miniatures despite the price. To make a long story short, their LEDs fit perfectly. The key to the perfect fit was that their LED outputs shine off of the edge of the LED board instead of shining straight out the front like most LEDs do. That allows the LED to be inserted into the narrow housing opening with its edge pointing towards the lens.
I eagerly clicked on your first link, thinking this might be a working wigwag crossing signal, only to be sorely disappointed that it’s only a dwarf signal. I need a wigwag for a highway crossing in Riverton. Be nice to find one that actually works.
I’m currently using some Showcase etched stainless semaphore parts to make smashboards for my drawbridge and a long-arm crossing signal with two red lights at each end of the “semaphore” board to protect a diamond crossing I have.
I recently built one of the Showcase etched signal bridges they offer. It is an excellent kit. Their products are very well detailed.
Those three-LED assemblies are above my pay grade to make by hand. I think I bought mine from Evan Designs. They look fantastic in a searchlight signal! The green is perfect for a signal light.
Someday there might be some kind of ultrasonic transducer or microwave magnet that will be able to make the Wig do its Wag. Would be neat to see.
What about a small blower, like from a steam engine smoke unit, that blows a stream of air toward the wigwag and that activates it? Sort of like one of those windmills you see with the guy sawing wood when the wind blows [:-^]
It could be mounted in a building nearby or somehow concealed.
