Hi Everybody
I have three places on my layout where I want to use a signal where I’m approaching a diverging route (facing point) and I want to have my block signal wired with two Logic Rail Signal Animators wired through the Tortoise as shown in this example using the diagram for the 2 head signal:
http://www.logicrailtech.com/sa_inst_supplement5.pdf
Thus when the switch is lined for the main the top head will show clear, the middle and bottom both red. As the train passes over the IR the signal will, of course, drop to red.
If I have the route set for the diverging track the top head will be red and the middle head will be green. This is the one I want to flash because in NYC RR practice a diverging clear signal is flashing, kind of a slow flash, one second+ on—one second+ off. I may force the middle head to stay yellow which would show a diverging approach medium.
Now, the Logic Rail has +5 VDC common anode and sinks the R Y G on the cathode side.
Circuitron makes a BF-3 adjustable rate flasher which would work since the flasher is powered independent of the output voltage but these guys are $25 each and I think I can come up with something less costly.
{from Circuitron catalog, I underlined the output feature}
BF-2 BASIC FLASHER - LAMP (BF-3 is same, but adjustable rate)
The BF-2 is a low cost universal flasher circuit
that will flash any incandescent lamp or Light
Emitting Diode load with a total current draw
of 250 ma. or less. The BF-2 can be powered
by any 8 - 18 volt AC or DC power source.
However, the DC load (lamps or LEDs) applied
to the output may be powered by a different
voltage source
