Im sure by now u guys know how my mind works i gotta question
so just out of curiosity would you like it if the company’s could come out with a compressor and air brakes and horns for G scale trains & O scale trains and started working on ways to downsize for the smaller scales?
Also i saw model size engines that run off of diesel fuel is there any way to put one of those into a model train engine cause that would be sweet to put a diesel engine in a O guage or G guage?
Those tire inflators that plug into the 12 volt outlet in automobiles have a pretty small motor and compressor. They should fit into G and maybe O scale models.
Mark Vinski
ill have to look around at the flea market experiment a lil but i think itd just be thrilling to make everyone do a double take to tell then u have a real air system on your train
U_O_A. Not to be a spoilsport, but only an observor of your ideas. See the comment I made on your solar/wind system.
As for this air brake idea: To me there is absolutely a thrill to “hearing” escaped air when braking. At stopsigns I “chase/shadow 18 wheelers” to hear all the noises. It was suggested the 12v compressors to inflate car tires might work. Remember: ask questions, 1. if a 12vdc generator were to be attached to your train set axles (that compressor needs 12vdc…it would be WORSE if the compressor were mechanically geared to the axle) had you considered how much drag on your train this would be?
2. To make it more prototypical there would necessarily be lots of weight added to rig the braking equipment.
Just saying. Best Regards endmrw0308251327
You need to see this website! It’s a mad scientist’s candy store!
They have Stirling engines, jet engine blueprints, all kinds of fun stuff! Their glow paint is the best in the world by the way!
Horns aren’t going to work as you expect – the sound doesn’t scale directly. You’ll need to make Helmholtz resonators, the same way Hornsby did for their live-steam OO gauge A4, and tune them to some appropriate chord – perhaps dopplered up to 85mph or better!
The likeliest source of adaptable diesel parts would likely be the model airplane industry – Google model aircraft diesels to start seeing what’s been done. A G-scale 710 would have dimensions roughly 8mm x 10mm, or about half the displacement of a typical small engine, but if you had 16 of them on a common crank or geared together you might have something interesting. Unfortunately also very, very, very expensive…
Well, I actually considered a fake airbrake system that operates electrically at one point…
